Abaaba |
Abaaba Renault 5 Driver
struan80 |
struan80 World Chat Champion
Posted: 23:16 - 04 Apr 2022 Post subject: |
No idea but I guess a rear wheel alignment after a tyre change or something may cause this. Take it your tyre pressures are all ok?
Could be your right bollock is bigger than the left causing unusual weight distribution. |
Abaaba |
Posted: 23:21 - 04 Apr 2022 Post subject: |
First thing I'd check is the wheel alignment. Could be the rear is misaligned on the adjusters or sometimes the front can be twisted slightly in the yokes. A CBR6 should track straight with no hands on the bars.
Have a look at the tyres and see if there's any uneven wear.
An old trick for straightening up the front end is to loosen the pinch bolts on the yokes and pump the front end up and down a few times with the brake on then re-tighten them. Not so loose as the forks slip down through the yokes but enough so they can move a bit if they need to.
You can check the wheel alignment with the bike on the mainstand and a straight edge held on the rear wheel so it's touching the tyre in two places and see if it's the same distance from two points on the front when the steering is central. You can even use a tight piece of string to do this. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
DJP |
DJP Crazy Courier
Posted: 10:48 - 05 Apr 2022 Post subject: |
Also check that you don't have any tight cables. Get the front wheel off the ground and check that the steering moves freely from side to side. ____________________ Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https |
Zen Dog |
Zen Dog World Chat Champion
Fizzer Thou |
notbike |
notbike Formerly known as notabikeranymore
Nobby the Bastard |
A100man |
A100man World Chat Champion
Posted: 11:44 - 08 Apr 2022 Post subject: |
stinkwheel wrote: |
I wouldn't expect that to make the bike to pull to one side either, the whole front end should be moving as a unit. Like many bicycles have a spring in one fork and damping in the other. |
Quite - and some motorcycles too I believe ____________________ Now: A100, GT250A, XJ598, FZ750
Easy-X |
Easy-X Super Spammer
Ste |
Ste Not Work Safe
Nobby the Bastard |
Easy-X |
Posted: 13:45 - 08 Apr 2022 Post subject: |
Ah yes, that was the word I was looking for ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Ste |
Ste Not Work Safe
Posted: 14:05 - 08 Apr 2022 Post subject: |
Yes, that diagram shows that the spring is just a spring and preload is an adjustment that's independent of the spring.
Springs can be changed to one(s) of a different rate and then the preload would need setting for that spring rate. |
Nobby the Bastard |
Posted: 14:17 - 08 Apr 2022 Post subject: |
Ste wrote: |
Preload acts on the spring, preloading its tension.
Compression damping is done by altering how open a valve is in the oilway used when the shock gets compressed, just like the rebound damping does the same for an equivelent valve in the return oilway. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
Pete. |
Pete. Super Spammer
Posted: 14:22 - 08 Apr 2022 Post subject: |
Preload applies only to springs, it's the amount the spring is pre-compressed before it begins to travel. Not seen any that you adjust with a screwdriver though.
Compression and rebound are two types of damping nowt to do with the spring.
Damping should not affect the geometry since once the fork stops moving damping has zero effect.as above, many bikes have compression damping on one fork and rebound on the other.
Edit:Nobby got in there first. ____________________ a.k.a 'Geri'
Ste |
Ste Not Work Safe
Nobby the Bastard |
SpiritMr89 |
SpiritMr89 Nova Slayer
Pete. |
Pete. Super Spammer
Fizzer Thou |
Hong Kong Phooey |
The last post was made 2 years, 16 days ago. Instead of replying here, would creating a new thread be more useful? |
