Luggage tracker in my scoot - good results
maxrpg
PostPosted: 18:59 - 24 Apr 2022    Post subject: Luggage tracker in my scoot - good results Reply with quote
I haven't had the cash spare to pay out for an expensive tracker yet, so thought I would try something else in the meantime just to see if it works.
I bought this a few months back: https://eshop.v.vodafone.com/uk/curve-gps-tracker#slate
And I have to say the results from using it have been pretty good. Currently located under my seat, takes about an hour to charge via USB power bank and depending on how often I ask it to update me on its location the battery lasts between 2-5 days, and I get charged a subscription fee of £2 a month.
I managed to set it all up, I can set perimeter fences in the app to alert me if it moves outside the fence and it alerts me if my scooter moves so much as an inch from its standing location. I often forget to turn off alerts and as soon as I take my scoot of the main stand I get an alert telling me its on the move. Which is really good. Annoying at times, but good.
I really like how it uses GPS, nearby WIFI and Bluetooth to work out and triangulate its location, which has been really accurate 90% of the time, I can request its location at any time and it shows it within seconds on a map and even logs where its been.
Its not really designed for tracking bikes but it has worked really well the last few months for me. At least now I have some temporary protection should my scoot be stolen.
Anyone else had good results with other cheap trackers?
I've seen a lot of trackers costing £100s that do pretty much the same as this one, I'm actually starting to wonder if investing in a more expensive tracker is even worth it now.
PostPosted: 19:19 - 24 Apr 2022    Post subject: Reply with quote
That could be useful and looks a lot cheaper than some
'motorcycle' ones I've seen that had a rats nest of wires bundled in with them.
'Motorcycle tracker' is usually marketing bullshit they don't specifically track bikes cars or anything else, they report their location, time and movement so bike, car, tractor, dog collar or kids lunch box its all the same process.
Battery life could be improved by some hacking and tapping into the bikes battery and supplying it via a 12v to 5v regulator.
I doubt it would take any more power than current alarms and possibly less ( depending on use of course, more talky more power)
xX-Alex-Xx
PostPosted: 19:20 - 24 Apr 2022    Post subject: Reply with quote
Sounds decent apart from the 2 day battery life.....
DILLIGAF
Ariel Badger
PostPosted: 21:12 - 24 Apr 2022    Post subject: Reply with quote
Add https://www.ebay.co.uk/itm/223029681184 and a two wire female USB and you can continually charge from your battery.
xX-Alex-Xx
PostPosted: 06:21 - 25 Apr 2022    Post subject: Reply with quote
I'd rather it not continually drain from the main battery. Easy enough to charge it when the bikes powered on, but I don't always ride every other day. There's enough trackers out there that can last a month or more between charges.
DILLIGAF
PostPosted: 07:45 - 25 Apr 2022    Post subject: Reply with quote
I have a cheap tracker on my boat. It's weird that you actually phone it and it then it gives you a google map picture of where it is. Battery lasts ages as it's only in use when you phone it. PAYG sim so cheap as chips to run. Cost something like £15 if I remember right.
Triumph Trophy Launch Edition
PostPosted: 07:49 - 25 Apr 2022    Post subject: Reply with quote
Do you regularly forget where you left your boat?
Triumph Sprint ST 1050
PostPosted: 09:04 - 25 Apr 2022    Post subject: Reply with quote
You forget lots of things when you reach my age. Laughing
But actually boat theft is surprisingly common. There is no compulsory register for inland boats so nick one, give it a coat of dulux in a quiet place and it gets very difficult to prove it is yours if you don't have some defining permanent feature. (mine has its name and hull number in weld in the engineroom.)
Most of the canal system is not accessable by vehicle so it's easier than you'd think to change the appearance of a boat without being seen.
PostPosted: 09:11 - 25 Apr 2022    Post subject: Reply with quote
Oh, I know it happens. I live right by the K&A.
maxrpg
PostPosted: 16:45 - 25 Apr 2022    Post subject: Reply with quote
I also thought about hooking it up to the battery but I'd hate the drain, I have a cheap 5,000mah power bank I use to charge it up when it needs it and it works well for me.
PostPosted: 17:20 - 25 Apr 2022    Post subject: Reply with quote
When you quiz it , can it tell you the battery status?
maxrpg
PostPosted: 17:59 - 25 Apr 2022    Post subject: Reply with quote
Yes, it includes the battery level with the location/alert info that it sends you. And it alerts you when battery is low.
PostPosted: 18:21 - 25 Apr 2022    Post subject: Reply with quote
Interesting. £36 per year is a bit steep for my pocket but at least it's a straightforward solution.
I probably wouldn't wire it into the bike electrics unless you're out and about regularly. The point of a more vehicle-oriented tracker is it knowing when to go into sleep mode (i.e. not moving.)
Kawasaki Jimbo
PostPosted: 12:34 - 30 Apr 2022    Post subject: Re: Luggage tracker in my scoot - good results Reply with quote
The ‘fence’ is about 100 yards in radius.
Does it have a motion alarm? I’ve got one but can’t see that feature.
Bhud
PostPosted: 14:23 - 30 Apr 2022    Post subject: Reply with quote
I bought one on the strength of this thread. In retrospect, it's fine, but it's an uncharacteristic purchase. There are more cost-effective solutions - I just didn't want to think about them. I like the Vodafone app - it's fast to load and to bring up the location of the tracker. I also like the fact I don't have to log in to the app every time I bring it up. I switched it to "performance" mode, and it does update every 5 minutes or so. It seems to switch itself to "everyday" mode if I shut down the app.
There is no motion tracker but a motion-sensing alarm is a cheap and subscription-free thing which works well. I use one like this (although not exactly the same - the seller of the one I bought is no longer registered on Ebay), except mine is designed to be wired up directly to 12V AC:
https://www.ebay.co.uk/itm/384796269696
I've fitted a fuse, inline with the battery, so there is a constant drain. However, the drain is absolutely minimal. The motion sensor is adjustable, and works well. It gives a warning signal if the bike is moved, and the alarm sounds if it's moved a second time before disarming it.
Kawasaki Jimbo
PostPosted: 15:51 - 30 Apr 2022    Post subject: Reply with quote
That one doesn’t message you though.
The bicycle version of the OPs device does have motion alert, so it’s odd if the original doesn’t.
https://eshop.v.vodafone.com/uk/curve-bike-light-and-gps-tracker
Kawasaki Jimbo
PostPosted: 11:52 - 02 Jul 2022    Post subject: Reply with quote
Not very good. I bought two in April, one for each bike to hopefully simulate the old DataTool pager the Kawasaki had years ago.
Arrow No movement sensor.
Arrow The ‘perimeter fence’ is too big to be effective. By the time I’d been alerted the bike would be well away.
Arrow ‘Beep’ locator is way too quiet.
Arrow Battery at first lasted a week but now won’t charge beyond 50% and then dies in one day.
Arrow Now struggling to connect.
Arrow One of the device-specific charging leads overheated and blistered the plastic sleeve over the USB plug.
Subscription cancelled.
The last post was made 2 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.71 - MySQL Queries: 13 - Page Size: 95.61 Kb
