Grease greees grease every #####' where !!
XT65
PostPosted: 12:13 - 12 May 2022    Post subject: Grease greees grease every #####' where !! Reply with quote
Alright all BCF, hope all's well and the covers are slowly coming off ..[saying that,it'll be SNOWING tomorrow Very Happy !]
Just wondering if I've been a bit stupid greasing my chain adjusters a bit considering what they're for ...?
They're new ones for an XR125 swingarm . the old ones were rusted fairly tight in there so i cleaned the arms out as best I could and then put some grease around the inner surface and inside the bolt holes of the adjusters -
Now I'm thinking it's not a smart move as they obviously need 'some' resistance to do their job..
But as they're locked in place once tension is achieved ,should I not worry about it ?
Thanks all
ThunderGuts
PostPosted: 12:28 - 12 May 2022    Post subject: Reply with quote
The torque on a rear axle is usually pretty high; unless the mating surfaces are like glass, I'd expect the grease to be squeezed out until the surfaces engage with each other. I think you'll be fine if the axle is torqued up correctly. Incidentally, that's possibly a bigger risk - grease on the threads of the axle (unless specified) will cause a much bigger tension on the axle than with a dry thread.
TG.
XT65
PostPosted: 13:45 - 12 May 2022    Post subject: Reply with quote
Thanks TG -yes I see your point there, but I'm not applying to the nut thread specifically , there's some on the thread end because of pushing through the adjuster holes but that will be dry as I can make it once I come to torque it up -
I'll keep an eye like tipex on it too once to torque spec [93Nm I think]
I'm thinking of the adjusters moving in [or out] of the swingarm ends when adjusting the chain tension - by using a bit of grease am I making it a harder job achieving and maintaining correct chain tension by giving them too much movement [because of the grease] [I was thinking of how the old ones had rusted up inside the arm ends so thought it couldn't be a bad thing against the weather I suppose]
I mean they're not falling out or anything they're tight in the arm ends- I'm just thinking on the micro level of movement when adjusting ..
ThunderGuts
PostPosted: 16:20 - 12 May 2022    Post subject: Reply with quote
The other thing you could do is just wipe down with a degreaser soaked rag the mating surfaces so they're dry? Unlikely to harbour much water if they're a close fit already. Good idea on the tip ex actually, I've seen that done elsewhere but it's never occurred to me to do that myself at home. Like it . . .
TG.
MCN
PostPosted: 18:38 - 12 May 2022    Post subject: Re: Grease greees grease every #####' where !! Reply with quote
Thanks all
Putting any lubricant on a fastener means the fastener will screw in more due to the reduced friction. Screwing in more means there will be more 'crushing' action from the fastener.
It shouldn't affect the resistance to falling out.
Simply not being tightened enough will let that happen.
Most Greases are Soap based. (A base Oil blended with detergents and magic stuff)
Because of the soap they are prone to absorb moisture. And therefore, require to be replenished at intervals.
There are waterproof greases but more expensive and not as easy to find.
The last post was made 4 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.08 - MySQL Queries: 14 - Page Size: 46.46 Kb
