HT Leads - understanding the terminology
PostPosted: 13:57 - 13 May 2022    Post subject: HT Leads - understanding the terminology Reply with quote
"Some red HT leads would look nice!" Let's just make some...
So this is for the ol' Triumph we're working on. Points have at some point (not by us) been replaced with a Dynatek* electronic ignition system and we've replaced the rectifier/zener arrangement with a conventional reg/rec unit.
First up copper vs. carbon leads. Copper is more "noisy" but as this isn't an EFI bike with loads of sensors does it matter? Also do screw-in type plug caps only work with copper?
Resistors. I get that carbon leads are themselves a resistance in the circuit so the equivalent for copper would be resistor plug caps or spark plugs with a resistor built-in. Erm... n00b question why/when does one need resistance? Shifty
Specifically does our old Triumph need resistance somewhere bearing in mind the retro fitted electronic ignition?
Finally actually making leads. I could see copper being a bit easier to work with and carbon leads definitely requiring a specific crimp tool. Just wondering whether the EMF noise from copper is even worth worrying about Thinking
*I'm wondering if the kit was ever intended for a Triumph, I can only turn up mentions of it sold for BMWs of the same era.
PostPosted: 14:23 - 13 May 2022    Post subject: Reply with quote
https://www.feked.com/spark-plug-ignition-lead-braided-ht-cable-red-black.html
or just put red shrinktube over normal HT lead.
PostPosted: 14:59 - 13 May 2022    Post subject: Reply with quote
Yes, cloth braided cable does seem appropriate Smile Do I need plug caps with the 5k resistor?
gt alex
PostPosted: 15:08 - 13 May 2022    Post subject: Re: HT Leads - understanding the terminology Reply with quote
.[/size]
I don't really know but I suspect these days every thing is resistive to reduce radio interference and "noise" in the bikes harness which maybe could upset something electronic on the bike.
I have a carburettor and cdi black box and have unscrewed the plug caps and removed the resistors replacing them with a short length of silver solder rod. I am also running copper HT lead which came from the local dirt bike shop (only place I could find it) and I an running non resistor plugs.
Its a 2002 bike and I have been running that way for 6months no ill effects and I believe I have added reliability.
We will see but I don't think it's a issue.
Bhud
PostPosted: 16:05 - 13 May 2022    Post subject: Reply with quote
I've run resistorless plug caps in both points ignition system bikes and ECU ignition system bikes, without any problems.
PostPosted: 16:23 - 13 May 2022    Post subject: Reply with quote
You say no ill effects but have you tried to listen to fm radio when the bike is running?
The resistors aren't to stop the noise affecting g the bikes system but to stop all the noise it creates in radio frequencies.
virus
PostPosted: 20:07 - 13 May 2022    Post subject: Reply with quote
as Nobby says, the resistors are noise suppression to prevent interference with electrical items such as TVs, AM/FM radios, CB / Ham radio, WiFi etc
So basically throw the resistors away and dont worry. so long as the Low tension side of the coil has the right resistance for the CDI then it will be totally fine. Putting 2.2 Ohm coils on a bike expecting 3 Ohm will result in it running like a bag of shit until the CDI just dies for example.
John
own: 81 xs1100g...
PostPosted: 20:45 - 13 May 2022    Post subject: Reply with quote
The dynatech website seems to recommend it.
PostPosted: 11:13 - 14 May 2022    Post subject: Reply with quote
Leakage to Ground/Earth.
Noise (if you're bothered.)
Watertightness encourages reductiin in potential for 'tracking' (leakage to earth) which leaks out all the energy used to jump the airgap under pressured conditions.
I prefer copper as when ever ive had issue with HT systems most commonly it was bastirt crabon leads and their shitey connection.
If you're real anal, one of those petrolhead sites that those weirdos who are 'intae cars' Rolling Eyes use.
There is a lot of tecspeek on somenof those sites.
Not much problem with ignition on modern electronic ignition systems really. The materials are better quality and the components dont suk as much as before. (Since spark ignition was invented, it seems like as long as it worked no fuker bothered to advance it or develop it much.)
PostPosted: 19:53 - 14 May 2022    Post subject: Reply with quote
Update: complete brain fart Sad The Dyna module is on the Kawasaki, the T140 actually has an original Lucas "ignition amplifier" Rolling Eyes
steve the grease
PostPosted: 20:09 - 14 May 2022    Post subject: Reply with quote
Running without either unsuppressed leads or caps is pretty much the radio frequency version of open pipes......... It pisses off a lot of people.
gt alex
PostPosted: 07:19 - 15 May 2022    Post subject: Reply with quote
I must just be anti-social then.
But wait, what if I run a braded earth shield over the out side?
gt alex
PostPosted: 08:11 - 15 May 2022    Post subject: Reply with quote
I have done exactly that.
Earth shielding on my high tension leads, not to be friendly to your TV but to get a better spark.
A layer of stainless braid, heat shrink and the ends have extra heat shrink to seal it, the tail on the braid is bolted to the frame.
B1N
PostPosted: 11:00 - 15 May 2022    Post subject: Reply with quote
If you look at the 'Pictorial diagram of a simple spark-gap transmitter from a 1917 boy's hobby book' inthe link below you can see how similar a spark gap transmitter is to a points ignition system, basically it is a spark gap transmitter.
https://en.wikipedia.org/wiki/Spark-gap_transmitter
The points act as The telegraph key, any wires of the bike loom connected to or near the ignition circuit will act as the tuning coil, the leyden jar is a condenser, the coil and the spark gap you already know.
PostPosted: 13:55 - 15 May 2022    Post subject: Reply with quote
When is a door not a door?
When its a Leyden Jar.
steve the grease
PostPosted: 18:50 - 15 May 2022    Post subject: Reply with quote
Construction and use stuff is points on your license.....
https://www.legislation.gov.uk/uksi/2002/2126/made/data.xht?view=snippet&wrap=true
PostPosted: 19:06 - 15 May 2022    Post subject: Reply with quote
Although it's going on a Triumph Bonneville. Presumably a Hinkley one if it has a Lucas ignition so radio noise supression isn't much of a concern. C&U isn't retrospective with the exception of seatbelts.
Old Git Racing
PostPosted: 23:23 - 15 May 2022    Post subject: Reply with quote
I think you overthink things a tad.
OGR
PostPosted: 10:31 - 16 May 2022    Post subject: Reply with quote
I should probably get that on a T-shirt Smile
B1N
PostPosted: 23:34 - 16 May 2022    Post subject: Reply with quote
I overthink, therefore I am. Thumbs Up
The last post was made 1 year, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 17 - Page Size: 112.24 Kb
