| Darylw27 |
 Darylw27 Nova Slayer
| Blau Zedong |
 Blau Zedong Banned
| jjdugen |
 jjdugen World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 12:36 - 15 Jan 2012 Post subject: |
Agree with above really; for 33bhp restrict, its probably not the most practicable start. And any more 'complex' twenty odd year old bike, doesn't suggest an easy time, for dependable every day transport.
They were a great bike, in their day though. Created at the height of the evolution era with major advanced being made almost weekly; Yamaha, the last to build a big four-stroke, last to make an across the frame air-cooled 'four'; went away, sat down with a clean sheet of paper, and to make a water-cooled motorcycle, created the FZ.
Brought to market in 1985, withing a year 18months of Honda ill-fated VF series, and Kawasaki's bench-mark setting GPZ6 & 900R, and while Suzuki laboured trying to avoid going water cooled with the 'oil-boiler' GSX's... brought together all the 'ingredients' of the modern sports-bike, and it has remained remarkeably 'unchanged' in topogrophy from the layout set by the FZ.
Its engine was water-cooled, with the cylinders inclined 45 Degrees to slant under what is essentially a 'beam' (Genesis) frame from headstock to swing arm spindle. (Had lower cradle loops, but removable) Cylinder inclination allowing down draft carbs and a large air-box under the tank, later leading to full 'Ram-Air' induction. It had multi-link mono-shock rear suspension, and conventional tele-forks up front. Yamaha got it 'right' all most straight off the drawing board, and it did, briefly, set a new bench-mark for performance.
But it wasn't a full-on 'Performance' bike; it was a sporting street-bike. This was probably its major failing.
It was a very, very competant 'All-Rounder', but the Suzuki GSX-R was pushing 'sports-bikes' down the 'race-replica' route, and against the fully faired Kawasaki's and Suzuki's, it was a little 'concervative', and the 750 'class' was waining, with the 500 class having grown to 550, and by then a full 600...
For probably ten years or more, it remained a very well regarded, and they held prices very well. A lot being brought in from the USA as 'Grey-Imports' in the 90's, along with the 'Tax-Buster' 700 model, that was the same bike but sleeved down to fall under a US import tarif capacity limit.
I looked long and hard for one in 1997, when I bought my VF1000; and had actually gone to look at a US-Import FZ700 when I found it, and have pondered them ever since.
NOW though; I dont think I would be 'keen' to take one on as a 'project'; I certainly wouldn't want one as a 'cheap ratter'; as there are much easier bikes to live with on the cheap, that do the job as well. If I was to get one, I would be looking up market for something nice and original, that would make a very 'useable' classic, for longer ride-outs and rallies and leisure riding, with possibility of occassional commuting, but NOT an every day rider. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| P.addy |
 P.addy Red Rocket
 Posted: 13:07 - 15 Jan 2012 Post subject: |
Wouldn't see a problem with the 33hp.
Flat mates barge GSXR750 is restricted....or was...
Apart from being slow, it coped ok! |
| jjdugen |
| Kickstart |
 Kickstart The Oracle
 Posted: 15:05 - 15 Jan 2012 Post subject: |
There were 3 basic models. Early ones with 4>2 exhausts and 16" front wheels, later (and most common) with 4>1 exhausts and still a 16" front wheel and the late bikes with a 17" front wheel
The engines are very tough. The weak point is the bearing behind the front sprocket which suffers if the chain is over tightened. Complete engine strip required to replace it. Valves are shimmed and meant to checked at 28k.
Build quality isn't bad. Not so good as a VFR750 but way better than a n early 1990s CBR600.
Top speed is around 150mph, but plenty of power everywhere and no real power band (although a Micron 4>1 will give it a big flat spot at low revs). The engine formed the basis of the FZR1000 engine (and later Thunderace, unrelated to the Thundercat), and if you want to tune one then various bits can be fitted to the FZ engine (easy to take them to 911cc), or if you don't want to keep the 6 speed gearbox you can fit the FZR engine. ~160hp is possible with a lot of work (and a large wallet), but it will be nowhere near 750cc by then.
Seat was rejected by the Spanish inquisition as being a too cruel form of torture.
Tank is a decent size giving a decent range (well past the point where the seat has killed parts of you anatomy) and even the fuel gauge isn't too far out. Electric reserve which works fell. Headlight is decent.
Weight is a long way forward and low down. Don't expect to manage to do a stoppy on one as it will almost certainly just lock the front wheel instead.
Really should put mine back on the road. Now has an Ohlins shock on it which I had rebuilt but is set up way too soft, but a pig to get at to adjust. So barely touched it in years.
When I bought mine I also considered a GPX750. A few years later in Aus for 3 months I had a GPX750 and it confirmed that I had made the right choice with the FZ being a far better bike (GPX seat was better though). Early GSXR was a far more crude bike and far sportier, but the FZ was more powerful with a more modern architecture, but weighed a fair bit more. The other main competitor was the VFR750, but these were quite a lot more expensive depite being reputedly sold at a loss.
Few more details on the models.
1FN type (the exact model name varies between some markets). Half decent adjustable and rebuildable rear shock. Half fairing, with a belly pan in some places. Vented brake disks (ie, a gap between the surfaces of the disks). Air assisted forks.
2MG type. Quite a few detail changes. Different pistons, a touch more power, very different ignition system (cdi, coils, etc are not interchangeable). Full fairing. Non vented but instead drilled disks. Different shape airbox and tank with a flush fitting fuel cap. Small extra bits on the top fairing to provide a bit of protection for your hands. Quite different rear suspension linkage and cheaper shock and forks.
Late type is very similar to the 2MG, but gained the wheels and brakes from the original FZR1000.
| Darylw27 |
| temeluchus |
| Kickstart |
| Atomic Punk |
 Atomic Punk Scooby Slapper
There is a gap of 10 years, 138 days between these two posts... |
| nicole6776 |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 nicole6776 L Plate Warrior
The last post was made 4 years, 36 days ago. Instead of replying here, would creating a new thread be more useful? |
