| Author |
| Kawasaki Jimbo |
 Posted: 23:01 - 30 May 2022 Post subject: Fuel-injected 2003 (5PW) R1 stalling. |
I’m on the verge of getting my fuel-injected 2003 (5PW) R1 hauled off to the bike shop for diagnosis and repair. Save me the ignominy and cost.
I didn’t use this bike through lockdown but I had stored it with a full tank and a dash of Silkolene Pro-FST. I’ve since emptied the tank completely (what came out looked clean) and refilled with fresh petrol. The bike also had a new battery this month.
It starts fine every time but once warmed up it stalls with any hint of throttle even in neutral and regardless of side stand or clutch lever position.
It has,
Fresh fuel.
New battery.
Charging system is working (13.5v).
Downpipe temperatures (IR gun) seemed similar.
Air filter is clean and housing is secure on throttle bodies.
No change with fuel cap open.
No crimped lines.
No air leaks I can find.
Clutch isn’t stuck.
Fast idle (wax) valve seems to be working. Removed and cleaned anyway.
Electrical connectors all good and clean.
New spark plugs.
4 new ignition coils. (Originals had resistance slightly over spec but new ones didn’t fix it.)
New air temperature sensor. (As above. Losing faith in electrical component specs.)
EXUP valve and fuel pump working.
No engine warning light.
Throttle position sensor is a possibility but diagnostics check out ok and a new one is £300. (It’s just a potentiometer!)
Valve clearances overdue. Suspect this but the problem came on suddenly, which suggests electrical to me.
I’m guessing a blocked injector wouldn’t allow easy starting.
Tempted to take a punt on a new TPS.
Would dodgy valve clearances allow easy starting and warm up, but stalling with any throttle opening? |
| Back to top |
| jaffa90 |
 jaffa90 World Chat Champion
| Back to top |
| xX-Alex-Xx |
| Back to top |
| Kawasaki Jimbo |
 Posted: 08:32 - 31 May 2022 Post subject: |
The dash has a nifty built-in diagnostic where you can roll the throttle and watch the numeric response. Fully closed = 18 (spec 15-17), fully open = low 90s (spec 97-100), but ran ok like this before. No leaps or stutters in the numbers as you roll the throttle across the full range. The TPS is a pain to get to. Yeah… maybe I will.
| Back to top |
| A100man |
 A100man World Chat Champion
 Posted: 10:16 - 31 May 2022 Post subject: |
| Kawasaki Jimbo wrote: | The dash has a nifty built-in diagnostic where you can roll the throttle and watch the numeric response. Fully closed = 18 (spec 15-17), fully open = low 90s (spec 97-100), but ran ok like this before. No leaps or stutters in the numbers as you roll the throttle across the full range. The TPS is a pain to get to. Yeah… maybe I will.
Can you unplug it and check those readings ona DMM? Does it come apart for cleaning (with contact cleaner for example) like the TV repair man* used to do .
* another career option consigned to the annuls of history ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Back to top |
| Easy-X |
 Easy-X Super Spammer
 Posted: 10:53 - 31 May 2022 Post subject: |
Logically when you open the throttle you're letting more air in. What should also happen is the TPS numbers go up. The ECU goes and looks up in its map how much fuel is required for a given throttle position taking into account air density, temperature etc. It then says to the injector how many milliseconds to open. There's other stuff like timing advance but that'd affect peak performance rather general operation.
Given the diagnostics do show the TPS output I doubt it's that. Blocked injector? What all of them?! (I'm assuming one throttle body per cylinder + injector.)
How about fuel pump? If there's no pressure maybe there's enough dribble for idle just from gravity  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| A100man |
 Posted: 11:03 - 31 May 2022 Post subject: |
| Easy-X wrote: |
How about fuel pump? If there's no pressure maybe there's enough dribble for idle just from gravity  |
.. good call. and where there's a fuel pump there's usually a fuel filter  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Back to top |
| ThunderGuts |
| Back to top |
| Easy-X |
| Back to top |
| UncleFester |
| Back to top |
| steve the grease |
| Back to top |
| Copycat73 |
 Copycat73 World Chat Champion
| Back to top |
| Kawasaki Jimbo |
 Posted: 19:18 - 31 May 2022 Post subject: |
| A100man wrote: | Can you unplug it and check those readings ona DMM? Does it come apart for cleaning (with contact cleaner for example) like the TV repair man* used to do  . |
Will do, but it’ll have to wait until Thursday.
| Easy-X wrote: | Given the diagnostics do show the TPS output I doubt it's that. Blocked injector? What all of them?! (I'm assuming one throttle body per cylinder + injector.)
There’s another diagnostic to test the injectors one by one, but it just makes them click. It doesn’t mean one isn’t blocked, - but the bike starts first time.
The fuel pump cycles as normal when the key is turned, and I know it works because I mistakenly left a hose off. Fuel pressure is something I haven’t tested, - but the bike starts first time.
| A100man wrote: | and where there's a fuel pump there's usually a fuel filter  |
The fuel filter is inside the pump, which is inside the tank. Removing the pump (or reinstalling?) according to YouTube involves snipping a plastic tab off. Apparently the filter is a pillow-like pad which I don’t think is even listed as a spare part. The tank and it’s contents look clean so although I considered the fuel filter as a possibility I decided it was unlikely. I’ll come back to it though.
| ThunderGuts wrote: | So to confirm, you can't get it to climb revs using the throttle at all? Does it have any kind of anti-stall (i.e. automated slight rev pickup when releasing the clutch) - if so, maybe try easing out the clutch in gear and see if the revs pick up a bit. Does the wax idle cause the revs to elevate when running from stone cold (today would be a good day to test this as it's pretty chilly at the moment). |
The engine stops on the merest whiff of throttle.
No anti-stall. This was 1st generation FI.
I’ve wondered about the wax-idle valve before. For a long time now the bike warm up has been a bit odd, like it starts at 1100 rpm and then after a minute the revs rise noticeably and stabilise, then gradually come down when the bike is warmed up and ready to go. It used to leap to high revs and only come down towards the end of the warm up. TPS perhaps, but the throttle response is exemplary on the move. Started yesterday in cool weather the revs didn’t rise much at all but the engine was happy to warm up and idle until I touched the throttle.
| UncleBFester wrote: | You got an IAT or MAP/MAF on that? |
I’ve changed the intake air temperature sensor. No change. It’s got other sensors though I couldn’t point at them, I’ll have to consult the service manual. They’re not flagging fault codes though.
The problem might be heat-related since the warm-up phase is fine. Once warm I can raise the revs without stalling by pushing back the spring-loaded bar that the wax idle unit was pushing against. |
| Back to top |
| Fizzer Thou |
| Back to top |
| xX-Alex-Xx |
| Back to top |
| Kawasaki Jimbo |
| Back to top |
| P.addy |
 P.addy Red Rocket
| Back to top |
| Kawasaki Jimbo |
| Back to top |
| Kawasaki Jimbo |
| Back to top |
| Robby |
 Robby Dirty Old Man
| Back to top |
| BRUN |
 BRUN Trackday Trickster
| Back to top |
| Kawasaki Jimbo |
 Posted: 18:57 - 03 Jun 2022 Post subject: |
I was a bit distracted today with hay fever and other stuff so I didn’t finish the job. M5 x 10mm hex head bolts were hard to find locally so I was thinking of cutting a couple down to size but instead plumped for cap head Allen bolts from Halfords, and I had to go back for flat and split lock/spring washers because the originals wouldn’t come off the old Torx bolts for some reason. I also bought a set of Bondhus Stubby head Allen keys which should make TPS access easier ‘next time.’ I don’t know why I think there’ll be a next time but I like to address annoying fixing issues. Call it an upgrade.
I haven’t got the throttle bodies entirely free, they just lift a couple of inches which makes TPS access easier, but various fittings still in place which I can’t be bothered to remove are offering some resistance. Consequently I dropped the fiddly 1cm bolts and washers, and it turns out these stainless steel bolts aren’t magnetic (a magnet on a telescopic stick being my No. 1 tool). I thought I’d been sold aluminium bolts but the explanation is probably that they contain austenite.
That’s where I left it. Based on experience I could faff around all evening and not get the job done, but it’ll go together at the first attempt (starting with Blu-tack on a stick) tomorrow. Know when to take a break, I say.
Sorry BRUN, it’s a cliffhanger. |
| Back to top |
| UncleFester |
 Posted: 19:28 - 03 Jun 2022 Post subject: |
As the late Dan Blankenship said, progress goes forwards AND backwards  ____________________ 2017 Z1000SX |
| Back to top |
| Kawasaki Jimbo |
 Posted: 18:58 - 04 Jun 2022 Post subject: |
Today I decided the throttle body unit would have to come free, and even that wasn’t easy what with stuck electrical connectors. Nothing wrong with them inside but the plastic just didn’t seem to want to release. Right decision though, the TPS installation was a lot easier.
I briefly wondered about going that bit further and doing valve clearances but I’ve never done it before and I’d only do it on a healthy bike, otherwise if it didn’t run I wouldn’t know whether I’d fixed the original problem and botched something else, or vice versa. One problem at a time. I already feel like I’ve bitten off more than I can chew but I will get this done. Mechanic’s hourly rates are looking like a bargain now though!
TPS installed, I had it upside down at first but I’d taken photos. I also noted that the throttle body is aluminium (I think) so I went easy on the new steel bolts, letting the spring washer do it’s thing rather than cranking down all the way. The TPS angle adjustment by reference to a voltmeter gave an odd, unstable reading, slowly climbing. I used the dash diagnostic to set it up but will try the voltmeter again when the throttle bodies are back on.
Throttle body re-installation isn’t going well. I thought I’d got it, tighten up the clamps and gave it a wiggle, it came loose. I’ve lightly oiled the rubber seals but the bodies just won’t go on.
I’ve now turned to alcohol indoors. Mañana. |
| Back to top |
| UncleFester |
| Back to top |
The last post was made 4 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
