to v or not to v |
Ariel Badger |
Ariel Badger Super Spammer
Posted: 09:23 - 13 Jun 2022 Post subject: |
You can measure them, there will be a specified minimum thickness for both types of plate, check the steel plates for flatness, check the edges of the basket for notches, check the release mechanism for smoothness of operation, if there is a push rod, check it's straight and corrosion free and measure the spring free length.
Anything out of spec needs replacing, most commonly friction plates and springs or some people would just replace them anyway.
Fot checking things are flat and straight, put them on a flat piece of glass and see if they rock about or if you can get a feeler gauge under them.
If it's all ok, clean off the plates in a solvent (petrol works) and give the metal plates a de-glaze by sticking a sheet of wet and dry paper to a sheet of glass using water and rubbing them in a side-to-side motion. Then thoroughly clean off any abrasive residue.
Usually scraping the old gasket off is the biggest bit of the job.
There is an argument for trying to keep the old oil then changing it after a few miles on new clutch plates because they tend to shed a bit of material which will then contaminate the old oil and filter. This can be thrown away with an oil change after 50-100 miles. Others may disagree. If you lean the bike far enough over to the left, you can usually get the clutch changed without losing any oil. Seen it done many times in a rally field.
In terms of sourcing plates and springs, I'd say there is a good argument for OEM parts and they can often be cheaper than pattern ones. I know this was the case last time i did the clutch on my VFR750, Honda did a complete clutch rebuild kit with all the plates, gaskets and springs included in little honda baggies for less than a set of EBC plates. Worth a look in any case. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
doggone |
doggone World Chat Champion
to v or not to v |
to v or not to v |
Skudd |
Skudd Super Spammer
sickpup |
sickpup Old Timer
sickpup |
sickpup Old Timer
Skudd |
Skudd Super Spammer
jeffyjeff |
jeffyjeff World Chat Champion
Islander |
Islander World Chat Champion
Skudd |
Skudd Super Spammer
A100man |
A100man World Chat Champion
Skudd |
Skudd Super Spammer
to v or not to v |
Islander |
Posted: 22:05 - 17 Jun 2022 Post subject: |
Either a gasket scraper or a stanley blade and lots of patience. There are no shortcuts |
to v or not to v |
Posted: 22:14 - 17 Jun 2022 Post subject: |
i was afraid of that ____________________ current bike Yamaha Thunderace.
its old and fat, but its a damned good ride. the bikes not bad either. |
Skudd |
Skudd Super Spammer
to v or not to v |
Skudd |
Skudd Super Spammer
The last post was made 1 year, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
