RickTaff |
RickTaff Nitrous Nuisance
RickTaff |
RickTaff |
WD Forte |
WD Forte World Chat Champion
RickTaff |
Posted: 20:54 - 25 Jul 2022 Post subject: |
That doesn't sound very nice. I'd be suspicious of a blocked slow running jet making one pot drop out at idle speeds. My VFR was just doing this and it sounded like a Ducati at idle
Are any of the header pipes leaking? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
RickTaff |
MarJay |
MarJay But it's British!
Posted: 22:32 - 25 Jul 2022 Post subject: |
MarJay wrote: |
Wow, E10 is a real bogeyman right? Sounds like your mechanic friend is obsessed. E10 can have negative effect on older bikes, but it's not immediate and it's a case of slowly causing issues with making fuel pipes brittle or corroding some brass parts. This'll take a LOT of time, and only happen if you let those parts sit in E10 for a long time. I'd suggest not routinely using E10, but one or two tanks full every now and again is not going to do any harm at all. |
Agreed. As a fuel it will make the sum total of fuck all difference in terms of the bike running unless it is very highly tuned with an advanced ignition and raised compression where you might notice the difference between 95 and 98 octane.
Even then, you wouldn't notice at tickover, it would onyl be an issue with the engine under load. My mates 400bhp supercharged drag bike would run on pump unleaded as long as you didn't go over 5,000rpm.
The fuel grade is not the problem. Running ti very low on fuel and getting small bits of crap from the bottom of the tank into the fuel system could be. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
RickTaff |
MarJay |
A100man |
A100man World Chat Champion
Posted: 11:19 - 26 Jul 2022 Post subject: |
RickTaff wrote: | it's effectively burnt my spark plugs and cause one, even 2 cylinders to drop |
has it though? let's see them. Yes it sound lik its running on two but my guess it will be any of coils, plug caps or actual plugs...
I had a single plug cap fail on my FZ and it took two cylinders out and also sounded terrible. you need good continuity on the full cicuit if there s a shared coil on cylinders 1/4 and 2/3. ____________________ Now: A100, GT250A, XJ598, FZ750
Zen Dog |
Zen Dog World Chat Champion
Posted: 23:58 - 28 Jul 2022 Post subject: |
MarJay wrote: | Most modern dealerships won't have any technicians left who remember your bike. Most won't even know what a carburettor is. Take it to an old school mechanic - independent but works on older bikes - possibly used to work for a dealer in the 90s. |
There's a guy local to me, was the mechanic in a Honda dealer for 25 years, now an independent. I wanted to get the valve clearances done on the VFR800 and I thought he'd be ideal. He put me off for months saying it was a winter job, fair enough. When I finally spoke to him about it (and we had clearly established that it was a pre-vtec 800FI), he told me that any noises that I was hearing from the top end were probably the camchain. But the 5th gen VFR doesn't have a camchain, it's the last gear driven version.
I don't know whether that should have put me off, but it did. I don't want to know more than the guy doing the work, even though he's undoubtedly more experienced than me at actually doing it. I remember stinkwheel saying years ago something along the lines of "you can only really trust work on the bike you've done yourself". And it's true. But I hate that it's true because I'm a mechanical moron. ____________________ Current - '94 VFR750FR, '00 VFR800FI Previous - '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win (chinese copy of an old Honda design with a C90 engine)
My bike trip around S.E. Asia 2010/2011 |
to v or not to v |
Zen Dog |
Irezumi |
Irezumi Nitrous Nuisance
The last post was made 1 year, 272 days ago. Instead of replying here, would creating a new thread be more useful? |
