Shunt regulator testing, minimum load?
kramdra
PostPosted: 18:20 - 01 Aug 2022    Post subject: Shunt regulator testing, minimum load? Reply with quote
Have a new but questionable regulator to test, before fitting on a 125 - not my bike... To test, I have the 3 phases connected but the output only to meter.
While cranking and idle, the output voltage has a max of 14.1v, which seems good. However when revving, it goes over voltage upto 22v - this should never happen.
As I understand it, shunt regulators work by shorting the generator coils to maintain the correct output. Is there a minimum load on the regulator for this to function correctly?
If so, I'll connect a headlight bulb accross the output and test again, rather than return.
Thanks.
Islander
PostPosted: 19:35 - 01 Aug 2022    Post subject: Reply with quote
You'd normally have a battery providing a load for the charging circuit so probably yes. It won't do any damage to provide one anyway.
WD Forte
PostPosted: 19:39 - 01 Aug 2022    Post subject: Reply with quote
Assuming the RR is OK
The only circumstances that come to mind are if both pos and neg
outputs on the RR are 'floating' ie not connected
the device has no ground reference to set the output to.
Clamp the neg to ground and try again
bikers smell of wee
The last post was made 4 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.9 - MySQL Queries: 14 - Page Size: 35.35 Kb
