to v or not to v |
Nutty |
Nutty Two Stroke Sniffer
Nobby the Bastard |
Islander |
Islander World Chat Champion
Pete. |
Pete. Super Spammer
Posted: 18:31 - 30 Jul 2022 Post subject: |
If the butterfly spindle is worn it'll leak air through the bushes but that will be obvious.
Have you done the vales and compression check? If one cylinder is low on compression or has tight valves it won't be firing as well as the next and if it's not firing as wll it will be producing less vacuum. ____________________ a.k.a 'Geri'
to v or not to v |
to v or not to v |
Pete. |
Pete. Super Spammer
to v or not to v |
Posted: 13:36 - 31 Jul 2022 Post subject: |
i think ive isolated the problem. the butterfly valve on cylinder 1 is not closing fully. im able to push it down about 1mm when it should be fully seated
does anyone have an idea as to what could be causing this? i cant see any obvious debris. ____________________ current bike Yamaha Thunderace.
its old and fat, but its a damned good ride. the bikes not bad either. |
to v or not to v |
Pete. |
Pete. Super Spammer
Posted: 19:22 - 31 Jul 2022 Post subject: |
My next step would be to pull the carbs and sort them on the bench. Get the carbs off, cables disconnected etc. Wedge up the four plungers (or if you're brave pull the tops and extract them). Hold all four up to the light and see if you can adjust them so that the crescent of light under each butterfly is equal.
If you're lucky all that's wrong is that you've got the adjusters too far out of whack. Set all of the balance screws to the tabs are dead centred between the two springs and go from there. ____________________ a.k.a 'Geri'
to v or not to v |
Islander |
Nobby the Bastard |
Pete. |
Pete. Super Spammer
Bhud |
Bhud World Chat Champion
Posted: 20:17 - 01 Aug 2022 Post subject: |
Bite the bullet and do it properly.
Start from scratch. Carbs off the bike, valve clearances DO, renew any dodgy carb-to-engine rubbers (replace fuel line and any vacuum line at the same time, regardless of whether it's needed), then go through carbs and get them done. Valve shims first though.
1) Carbs clean and all passages that you can reach: clean.
2) Do you need to split carbs? Check by blowing down the fuel line tube while tilting it, for blockages (there will be resistance if there's dirt). If not, then leave it and don't split (more trouble than it's worth sometimes).
3) Float levels reset to factory spec.
4) Check jets and emulsion tubes are clean, especially pilot jets.
5) CV carbs: check diaphragms carefully, and replace where there are any tears.
6) Are your slides scored and are they sticking because of this? First things first: blast all your springs with carb cleaner, because return springs get clogged with dirt. After that, they should return smoothly. If not, then you MUST check if your main needle is bent. It should drop straight back into the main circuit. Is that OK? Then I (personally) don't have much of a problem with a dab of oil on the slides. See if that makes a difference. Beware though, that if it's wear in the throttle bodies (carb barrels) you will need new ones, or the problem will reappear in the winter.
7) Bench sync of carb bank.
8) Reinstall carb bank, get engine warm, then properly sync.
May take a bit of work but once it's done it's done. Just one of those things with bikes: a bodge/fix will do most of the time but not all the time. Sometimes you've got to go right through it. Good luck. |
to v or not to v |
Posted: 21:40 - 01 Aug 2022 Post subject: |
would love to do the valve clearances Bhud, but thats way beyond my capabilities ____________________ current bike Yamaha Thunderace.
Nobby the Bastard |
Zen Dog |
Zen Dog World Chat Champion
Posted: 21:58 - 01 Aug 2022 Post subject: |
Nobby the Bastard wrote: | He didn't mention valve clearances. |
Bhud wrote: | Start from scratch. Carbs off the bike, valve clearances DO, renew any dodgy carb-to-engine rubbers (replace fuel line and any vacuum line at the same time, regardless of whether it's needed), then go through carbs and get them done. Valve shims first though. |
____________________ Current - '94 VFR750FR, '00 VFR800FI Previous - '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win (chinese copy of an old Honda design with a C90 engine)
My bike trip around S.E. Asia 2010/2011 |
Nobby the Bastard |
Kawasaki Jimbo |
Posted: 22:26 - 01 Aug 2022 Post subject: |
to v or not to v wrote: | removing the carbs from the bike is a scary thought, im worried ill do even more harm.
looking at the manual it seems quite involved. the coolant has to be drained before you can even start. |
You’ll surprise yourself. I have. Any job will take at least three times as long as you think it will, but do your research (forums, service manuals, parts microfiches), take photos of every little thing from different angles, make mental notes of the disassembly process and know it’s just a collection of bits bolted together in groups.
Having the right tools for the job helps, eg. Japanese Industry Standard (JIS) screwdrivers. Not all cross-heads are the same. Also a garage or roomy shed where you can abandon the job and come back to it after tea, or tomorrow.
The hardest part is the old connectors which won’t release, the corroded bolt/screw heads which round out, and the hardened rubber boots which won’t release and then wont accept the reinstallation. There’s always a way though. Also don’t over-tighten stuff. Lacking ‘feel’ I rely on torque wrenches.
It helps that I have two bikes so I can afford to take one off the road for an extended period and still ride. So get a second bike!
I figure if it all goes wrong I’ll get my friendly local bike shop to pick the bike up and fix it, after all it’s already part-disassembled, but so far it hasn’t been necessary. |
Fizzer Thou |
Posted: 23:43 - 01 Aug 2022 Post subject: |
You will not need to drain the coolant so as to remove the carbs.
I found it easier to leave the throttle cables attached to the carbs.Just take the throttle apart at the handlebar and unthread the cables through the frame.You will thank me when you do this as the cables are a b'stard to reattach otherwise.
When removing the cam cover to check the valve clearances I found it a lot easier to drain the coolant so as to pull the radiator forward for better access to the cams,which need to be removed as and when the shims need to be changed.
The cost of doing shims on an engine like this will be upwards of £350-£500 if taking to a shop to be done.If you choose to go that route then remove as much of the bodywork as possible as you will be charged for this.
I have seen the post on the exup1000.co.uk forum
I am on there as YAMAEXUP ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
Pete. |
Pete. Super Spammer
to v or not to v |
The last post was made 1 year, 267 days ago. Instead of replying here, would creating a new thread be more useful? |
