Kawasaki Jimbo |
Posted: 13:46 - 25 Sep 2022 Post subject: |
I should have put this in Workshop but never mind.
It turned out that the clutch was stuck too*, and I couldn’t free it by shunting the bike forward in gear so today I took the clutch cover off and the plates out. Several were stuck together but came free without too much effort, albeit with gentle tapping and prising. They weren’t going to loosen up via their natural rotation forces in-situ.
I bought this bike around 2005 with 3000 miles on it so there should have been no reason for the previous owner to mess with it. Some additional sealant on one side of the gasket, and the fact that some plates were not in the correct order (friction plate - metal plate - friction plate) tells me he did, but possibly just tinkering.
The photo shows the order they came out, from top left to bottom right.
https://i.postimg.cc/nzPLMC5j/08-D7-AAC0-2-C73-48-DC-9239-208-E9-CFBF721.jpg
Clutch reassembled, new gasket coming early this week and I’ll do an oil change (it’s due). I’ve crimped the relay connector pin but having mangled the plastic connector block a bit I’ll need to do a good job sealing it. I’ve got heat shrink and I’ve seen something called ’potting compound’. Has anyone used that?
* I was definitely barking up the wrong tree when examining the switches. If the corroded relay (especially on the side stand terminal) wasn’t causing a problem it was on the way, so that was a good discovery. Process of elimination, I guess. However the immediate problem looks to be the stuck clutch due to little use recently. This all started with an unrelated but necessary TPS replacement. The Yamaha hasn’t enjoyed lockdown. The Kawasaki continues to be relatively bullet-proof. ____________________ '93 Yamaha XJR400 grey import (p-ex’d), '99 Kawasaki ZX6R (nicked), another '99 ZX6R (still got it) and '03 Yamaha YZF-R1 (still got that too.) |
Kawasaki Jimbo |
Posted: 21:54 - 02 Nov 2022 Post subject: |
You've bought the harness now but for future reference, OBD plugs/sockets have 16 pins and can be bought for under a tenner either with crimp terminals or flying leads already attached.
EDIT: Potting compound is useful for filling in housings with electronics in them to render then waterproof (classic place you'll see it is the black plasticy stuff in the centre of a reg/rec).
I'd probably have repaired that connector with thickened epoxy though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Kawasaki Jimbo |
grr666 |
grr666 Super Spammer
Posted: 23:52 - 02 Nov 2022 Post subject: |
I do admire you guys pulling your bikes to bits like that, I'd happily pull most things apart in a house but my mechanic
skills are limited to bolting uncorroded things on and off. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Kawasaki Jimbo |
The last post was made 1 year, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
