robertpnz |
robertpnz Derestricted Danger
Posted: 20:54 - 23 Aug 2022 Post subject: 2008 Honda CBF250 (Aka CBX250 Twister) Idle issue |
Hey everyone, i have a 2008 Honda CBF250 with 22000km that just wont idle properly. It can be quite hard to start when cold and even when i use choke i have to give it a little bit of throttle. Once it is warm and at a good operating temperature the idle will sometimes hang at around 3000-4000rpm and sometimes come down slowly or not come back down at all. (The standard idle is 1500 +/- 100rpm)
https://www.youtube.com/shorts/VCIhN6fAB30
I couldn't find any vacuum leaks between the carburettor and the engine.
Spark plug is good
Petcock seems fine although i will check again. Non vacuum type.
I have had the carburettor out and given it a good clean with carby cleaner and some air. Its a Keihin VEA2A CV carb
The main jet is standard 142
Pilot jet is standard 45
The float needle valve seemed ok as did the non adjustable float. The only thing i did notice was that when measuring the float height as per the workshop manual i measured a float height of about 22mm at the highest point of the float (it should be 18.5mm) But i am not sure how this could be as it is a fixed non adjustable float? I am unsure if i am taking the measurement from the wrong place as the manual is Spanish to english translation. I am using a vernier gauge as i do not have the correct tool.
I checked the diaphragm and slide and that all seemed to operate correctly.
Things i am going to check next.
Choke circuit.
Still need to check the small fine mesh fuel filter at the inlet of the carb as i didnt realise it was there.
Valve clearances
It does have a very small fuel weep on the float bowl as the gasket is knackered. Ive got a carb kit on its way from ebay.
Any help would be much appreciated. Thanks all.
Rob. New Zealand
Nobby the Bastard |
robertpnz |
jaffa90 |
jaffa90 World Chat Champion
robertpnz |
jeffyjeff |
jeffyjeff World Chat Champion
robertpnz |
Nutty |
Nutty Two Stroke Sniffer
jaffa90 |
robertpnz |
Robby |
Robby Dirty Old Man
robertpnz |
robertpnz |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 08:31 - 20 Sep 2022 Post subject: |
https://bikesandtravels.com/biker.aspx?ride=822 ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
RiderJake |
RiderJake L Plate Warrior
jaffa90 |
robertpnz |
The Shaggy D.A. |
Robby |
Robby Dirty Old Man
robertpnz |
Posted: 07:07 - 24 Sep 2022 Post subject: |
Ok i will do a compression test and see how its looking. Could be a case of having to whip the head off and re lap the valve seats. I took the tank off and removed the long filter on the petcock. It had bits of dirt stuck in it. I removed it all put the tank back on and still no joy with the surge issue.
Here is it running after replacing the float and re doing the valve clearances. It idles fine once its up to a good operating temp but until then it wont idle. But idling better than before.
https://youtube.com/shorts/5ZHEHhNmTM8 |
robertpnz |
Posted: 20:59 - 08 Oct 2022 Post subject: |
Hey, i did a cold compression test and it came back at 132psi. I also managed to temporarily diagnose the surging problem by pulling off the overflow pipe on the left side of the carb. This overflow pipe runs down underneath the bike and it seems the airflow under the bike was upsetting the pressure in the carb. |
jeffyjeff |
The last post was made 1 year, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
