xX-Alex-Xx |
Posted: 20:07 - 02 Sep 2022 Post subject: How generic are radiator caps? |
Got home from an hour's ride to find the bike had pissed a small amount of coolant onto the driveway. Had a look at the overflow tank (which is behind the sump) and it was beyond full. Dropped back down to half again after the bike cooled so I suspect the radiator cap (either that or the bike knew I was thinking of changing the coolant soon anyway so decided to help )
Trouble is I can't find a new cap (in the UK) specifically for the GSR-750. Any ideas what other models of zook would be ok ... I'm assuming they're fairly standard across the range. ____________________ DILLIGAF |
xX-Alex-Xx |
jeffyjeff |
jeffyjeff World Chat Champion
xX-Alex-Xx |
Posted: 12:01 - 03 Sep 2022 Post subject: |
Looks like the rad cap so far. No extra pressurisation of the pipes when revved, and the coolant reservoir only raises when the bike is hot. New one on order so fingers crossed... Good excuse to get another Gixxer thou if not ____________________ DILLIGAF |
Fizzer Thou |
Posted: 12:48 - 03 Sep 2022 Post subject: |
Test the original radiator cap in a pan of water
Suspend the cap in a pan of water and slowly bring it to the boil.If the cap spring mechanism functions as the water gets warm then it will indicate as faulty.
The same procedure is used for testing a thermostat. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
xX-Alex-Xx |
DJP |
DJP Crazy Courier
Posted: 21:32 - 03 Sep 2022 Post subject: |
The symptoms that you describe are typical of rad cap failure on Suzukis in my experience. ____________________ Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https |
WD Forte |
WD Forte World Chat Champion
jeffyjeff |
xX-Alex-Xx |
Posted: 08:24 - 04 Sep 2022 Post subject: |
Service manual states 14-17 psi for the cap. ____________________ DILLIGAF |
WD Forte |
xX-Alex-Xx |
xX-Alex-Xx |
jeffyjeff |
Islander |
Islander World Chat Champion
Fizzer Thou |
Bhud |
Bhud World Chat Champion
The last post was made 1 year, 229 days ago. Instead of replying here, would creating a new thread be more useful? |
