P. |
P. Red Rocket
Posted: 18:34 - 10 Sep 2022 Post subject: Tank rust |
Hola
So my new to me bike is a little rusty in the tank
https://imgur.com/a/XP9DVxv
What's the best/safest/most effective way to clean this. It doesn't look too bad, but I want to sort before it gets much worse. It's a CBF600, carb variant.
Thanks all |
Nobby the Bastard |
Islander |
Islander World Chat Champion
Posted: 20:23 - 10 Sep 2022 Post subject: |
POR-15?
If you just treat the rust it's going to come back. It's probably better to line it. |
trevor saxe-coburg-gotha |
Posted: 20:47 - 10 Sep 2022 Post subject: Re: Tank rust |
Paddy. wrote: | Hola
Thanks all |
That actually looks pretty bad to me, and I certainly wouldn't want any of that crap getting into the carbs.
There are several tanks on eBay that look sound (probably not right model though). Doubtful they're going to be the right colour, - but at least they won't be full of crud. They're all sub £100 so relatively cheap for a tank imo. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
Bhud |
Bhud World Chat Champion
A100man |
A100man World Chat Champion
Posted: 23:51 - 10 Sep 2022 Post subject: |
Vinegar takes forever because it;s weak, I;ve also tried electrolysis with not much success.
For me it's phosphoric acid every time. about 15% Conc is all you need.
A bloody good shake with a few handfuls of wood-screws will get into the corners
and get rid on most of the loose stuf. Then brim the thank with acid. (almost). leave some air for sloshing - you will also have to make blanking seals for the tap and sender. I'd leave for 24 hr sloshing when you can remember.
Rinse with water then swill out the tanks with meths/ethanol to collect any remaining water.Never bothered with a liner just fill with fuel.er.
This method may of course reveal pin holes in which case leading or if you must a liner ____________________ Now: A100, GT250A, XJ598, FZ750
jaffa90 |
jaffa90 World Chat Champion
Robby |
Robby Dirty Old Man
Posted: 17:56 - 11 Sep 2022 Post subject: |
My usual thing is phosphoric acid, and I've done a lot of rusty tanks with it. Full instructions:
First thing to note. Phosphoric acid will kill rust and leave the steel looking galvanised, but it also eats through aluminium and will get past some rubbers (but more slowly). So any aluminium parts like fuel tap and fuel sender must be removed and the holes plugged off. I tend to make up a little metal plate to bolt over the hole(s) with a bit of hylomar blue. Some of the acid will drip past this, but not much, and it doesn't harm paint that much.
Do as much of this as possible outside, or in the garage.
1. Clean out the tank. I don't mess around with handfuls of bolts generally, because it can be a pain in the arse getting them out. I drain the fuel, fill and empty with water a couple of times, then fill with a mixture of caustic soda and water and leave it for an hour or so. This shifts any dirt, sludge, basically anything organic and emulsifies anything oily.
Drain and rinse a couple of times with water. If the fuel tap hole is plugged off, a squeezy siphon pump works well for getting liquid out.
2. Acid time. I buy a 4 litre bottle of 40% phosphoric acid off ebay, pour it in the tank, and fill the rest of the tank with warm water from the tap up to just below the filler neck.
Do not overfill. The process makes bubbles. If you overfill, these bubbles will collect in a nice pocket and force acid out the filler hole, all over you tank.
Let it sit for at least 4 hours, longer if you feel comfortable with it. It will make fizzing noises. If you shine a strong light in the filler, you should be able to see how it's working.
3. Finishing off. Drain the acid, rinse a couple of times with water. Get as much water out as possible. I then pour in a bottle of meths and swill is around, then drain it off. That means that any water remaining is at least mostly meths, not mosly water.
If the tank is going back into use, refit and fill up with petrol as soon as possible. If It's going into storage, you want to get something on that metal to protect it from rusting. I tend use a mixture of engine oil and WD40.
No matter how much water you think you got out, you will get some in your carbs next time you switch on to reserve. Carry a screwdriver to drain the float bowls for when this happens.
I don't use any kind of tank liners. They might work, but I've had them fail in the past so I avoid them.
Both the caustic soda and the phosphoric acid can be poured down the sink or loo to dispose of them. Phosphoric acid will make your loo very clean, it dissolves limescale. |
P. |
P. Red Rocket
A100man |
Posted: 20:32 - 11 Sep 2022 Post subject: |
So, phosphoric acid it is then..
A100man |
Posted: 20:35 - 11 Sep 2022 Post subject: |
oh yeah and no tank liners.. ____________________ Now: A100, GT250A, XJ598, FZ750
P. |
P. Red Rocket
Posted: 20:43 - 11 Sep 2022 Post subject: |
Yeah cheers, I'll use the method Robby suggested as you also stated, see how it goes. Gotta work out how to get 10l out |
redeem ouzzer |
The last post was made 1 year, 226 days ago. Instead of replying here, would creating a new thread be more useful? |
