Quad bike - diesel instead of petrol..
PostPosted: 21:01 - 16 Oct 2022    Post subject: Quad bike - diesel instead of petrol.. Reply with quote
A friend has stuck diesel in his quad bike instead of petrol. It’s barely running / not running at all. Am I right in thinking fuel tank off, drain fuel system / carb and flush through with petrol and we should be ok?
Any hints please?
PostPosted: 22:31 - 16 Oct 2022    Post subject: Reply with quote
Should be, seen it done with bikes a few times and they lived to tell the tale.
Not sure about the fuel pump, some car ones have o-ring seals that get damaged by the wrong fuel. More often the other way though (ie petrol through a diesel pump). Also if it's new enough to have fuel injection and exhaust gas sensors, you can yak up the sensor causing a fault code.
Maybe clean the plug, I bet it's pretty sooty by now.
PostPosted: 22:37 - 16 Oct 2022    Post subject: Reply with quote
Diesel engines are too heavy to put in a bike or a quad.
And their acceleration characteristics are not enviable.
I hope this helps.
PostPosted: 22:39 - 16 Oct 2022    Post subject: Reply with quote
I hope this helps.
Polaris make a diesel quad. It's ok.
ThunderGuts
PostPosted: 06:54 - 17 Oct 2022    Post subject: Reply with quote
I would have thought the power delivery of a diesel would be ideal for a "working" quad, towing trailers up still inclines etc...?
TG.
1198
PostPosted: 12:52 - 17 Oct 2022    Post subject: Reply with quote
Fuel tank removed and thoroughly drained, then washed out with unleaded. Drain for carb loosened and emptied, then left open until empty. Tank filled and fresh petrol allowed to fill the system until proved from the carb drain.
Jump leads bodged from a electric light wire and jump started from aHonda Civic. Sorted!
PostPosted: 12:53 - 17 Oct 2022    Post subject: Reply with quote
Now you're farming!
PostPosted: 13:22 - 17 Oct 2022    Post subject: Reply with quote
stinkwheel wrote:
Now you're farming!
Well I hope he is a farmer or has some other need to cross the fells with a bale of straw on the back. Urban quad bike riders are a wretched curse.
1198
PostPosted: 13:27 - 17 Oct 2022    Post subject: Reply with quote
I’m definitely not an ‘urban quad bike rider’ - it’s used for farm tasks, no more, no less. I would be lying if I said I hAted riding it though, in small doses at least!
PostPosted: 13:50 - 17 Oct 2022    Post subject: Reply with quote
UK Electric Lighting is normally 220-240 Volts A/C.
Your quad is probably 12 volt D/C.
You won't be able to start a quad using 220 Volts A/C.
PostPosted: 13:58 - 17 Oct 2022    Post subject: Reply with quote
He just used house electrical cable connected to a battery.....
Triumph Sprint ST 1050
The last post was made 3 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 69.08 Kb
