Ariel Badger |
Ariel Badger Super Spammer
grr666 |
grr666 Super Spammer
Posted: 21:42 - 17 Oct 2022 Post subject: |
I'd run a mixer from a standard 3kva 110v tranny without any worry. Can't see an issue. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
to v or not to v |
Easy-X |
Easy-X Super Spammer
Ariel Badger |
Islander |
Islander World Chat Champion
Posted: 22:05 - 17 Oct 2022 Post subject: |
Yep, 2.6kVA roughly translates to 2.6kW which is 2,600W. It should be fine - most of the issues with running inductive loads like electric motors are down to inrush currents on startup. |
ThunderGuts |
Posted: 09:02 - 18 Oct 2022 Post subject: |
Only other thing to be wary of is what voltage your mixer is and if the generator is compatible; if the mixer is designed for site use then it is likely to be 110v and will have a site plug type, if it's intended for domestic use more likely to have a 3 pin plug and 240v. Just check your genny has the output and socket(s) and/or adaptors to suit. ____________________ TG. |
Easy-X |
The last post was made 1 year, 236 days ago. Instead of replying here, would creating a new thread be more useful? |
