Wattybanker |
Wattybanker L Plate Warrior
Posted: 16:37 - 20 Oct 2022 Post subject: Can’t find correct regulator for my Chinese Bike |
Been working on a Pioneer XF125L-4B over the summer this year. Recently it’s had a new wiring loom put in. I had a problem with the fuse blowing, circuit drain, things not working. The new loom seems to have remedied this but I noticed a corroded terminal on my regulator and I feel that’s probably my problem.
I’m not at all experienced in Electronics, beside a computer this is my first foray into dealing with an electrical system on this scale. So it’s very hard for me to get my head around the wiring diagram to accurately follow which wire goes where and leads to what. Online resources aren’t a lot of help. The wires in the physical loom don’t exactly match the diagram either.
The wiring diagram is here on page 41 https://pdfslide.net/amp/documents/pioneer-xf125l-4b-owners-manual.html
The reason I’m saying all this is because I’m struggling to find a replacement rectifier for this particular circuit, as well as wiring this bitch up. I seemed to have a complete circuit, beside the brake light being stuck on before the fuse blew again. The regulator is a difficult find because unlike many modern ones. The one I’ve got has a 5-6pins as well as a negative wire that connects to the negative terminal on the battery, with a green grounding wire extending from that connection as well. Most modern ones lack this extra wire that seems essential to completing the circuit.
Any advice or guidance on the subject (beside burning the whole thing and getting something else) would be extremely helpful. This is the biggest road block I’ve hit so far preventing me from enjoying the bike.
Some extra information I’ll fill in here for anyone that’s feeling extra helpful. My main reasons for fucking with the electronics on this bike was because of a drain in the circuit that was rinsing the battery in 1 day as well as the fact that my lights weren’t getting bright enough. The speedo, rev-counter, mileage clock and fuel gauge were all non-functioning or semi-working. Strangeness such as the rev-counter being unable to go about 6k. So originally just wanted to get to the bottom of that, which I’m still scratching my head on. |
WD Forte |
WD Forte World Chat Champion
Posted: 17:38 - 20 Oct 2022 Post subject: |
Took a few seconds to find on ebay
https://www.ebay.co.uk/itm/185599524132?
A regulator is a regulator so any 3 phase reg/rec will probably do
especially on a chinese bike.
Edit:
Hang on just had look at that shitty, grainy diagram
It doesn't use a common 3 phase regrec
the diagram shows the stator has
2 phase wires to the RR
1 is for the AC source coil to the CDI box
2 for the pulser connections to the cdi box
and possibly 1 for ground, no colour shown ____________________ bikers smell of wee |
Wattybanker |
Posted: 19:23 - 20 Oct 2022 Post subject: |
WD Forte wrote: | Took a few seconds to find on ebay
Edit:
and possibly 1 for ground, no colour shown |
Thanks for taking the time. Yeah as you pointed out the diagram is awful, some of the words aren’t even readable. This bike has been a nightmare because of the very little information out there specific too the bike as well as parts, which CMPO (the Uk distributer) doesn’t even bother to stock.
A lot of what you said doesn’t make a lot of sense to me becase of my lack of experience with this stuff. I thought the stator was a seperate thing to the Regulator.
I’m sorry but I really don’t know wtf I’m even talking about. I can make out components but other than that I’ve got no knowledge. I’ll do a bit of Googling tonight, I’ll do my best to digest what you’ve said. Idek what phase wires, AC source coils or pulser connections are.
If it isn’t a common regulator how do I find one similar, I don’t have that experience to ensure I get the right one.
stinkwheel wrote: | What's shown on the wiring diagram does not tally with what you describe in your post.
No ground connection on the reg/rec on the diagram, it looks like a single phase split lighting/charging coil on the diagram similar to the setup on a CBF125.
Maybe post a picture of what you've got? |
Yeah maybe my descriptions a bit off. In the bottom right of the diagram there is the battery and coming off the negative terminal is the wire I’m talking about, it splits off to the regulator and the grounding wire which leads to nowhere on the diagram. Idk if that’s what you’re describing but I’ve got a picture of the wire in question.
https://ibb.co/7J086YX
Thanks for uploading the diagram too. If that’s not the wire I’m holding then what wire should it be? And where does that wire from the regulator go? |
Nobby the Bastard |
Posted: 19:44 - 20 Oct 2022 Post subject: |
That wire you have in your hand is a honking great big thick earth wire. It has nothing to do with the reg/rec, it's just attaching to the frame with a ring terminal using one of the same frame mounting bolts as the reg/rec. You usually only see wire that thick going to a starter motor, I wonder if it's been added later to try to fix a bad earth? In any case, it wont do any harm to leave it connected.
I should point out the frame on your bike acts as an earth connection, all the metal bits of the bike attach electrically to the battery negative. According to your wiring diagram there should be two wires attached to the battery negative, one going to the loom, the other going to a frame earth connection, both of the black and white.
I wonder if that's the original reg/rec. In any case the wire colours do not match the wiring diagram. The diagram shows a red, yellow, pink, black on white and black. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Posted: 20:04 - 20 Oct 2022 Post subject: |
I'll add that the wiring diagram above is very difficult too interpret, it's so fuzzy that the little dots that indicate two crossing wires making a connection can't be seen.
I'm pretty sure it's got two charging phases (pink and yellow), a red output, and a black and white earth. The black I'm not certain about, I think it's proibably a "sense" wire to monitor the voltage in the loom.
I found this which looks very similar to what you have on the bike in your picture, right down to the wiring colours:
https://www.ebay.co.uk/itm/172427411264 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Nobby the Bastard |
Nobby the Bastard |
WD Forte |
Posted: 22:38 - 20 Oct 2022 Post subject: |
You say the colours don't match what you have
Just found this Lexmoto one which is functionally very similar
and may help ( its even got a fuel gauge)
Dunno what bike its for but Lexmoto use Honda colour conventions
for the most part.
Stick some pics up of what you actually have
https://imgur.com/iF5h8vf.jpg ____________________ bikers smell of wee |
WD Forte |
WD Forte |
WD Forte |
Wattybanker |
WD Forte |
The last post was made 1 year, 180 days ago. Instead of replying here, would creating a new thread be more useful? |
