mariust5 |
mariust5 Derestricted Danger
Posted: 18:55 - 26 Oct 2022 Post subject: Cbf 125 headlight not working |
Hello everyone , been reading the forum a while but never posted before .
I got a 2011 CBF125 for my son as his 1st bike off Marketplace , seller did say that the lights might need sorting and i'm up for a challenge usually but this one has me beat .
The bike has aftermarket switches, lights and dials and the wiring is a little on the bad side but it all works part from the main beam headlight and the dials won't light up .
Indicators work , brake lights also , there is a little bulb in the headlight assembly also and that comes on when the engine is running but sometimes flickering so that leads me to believe it might be the stator ?
Would the engine still run fine if the stator was bad ? I tried to take the cover off for a visual inspection but on removal of top bolt from chain cover something was coming out like some sort of oil and did it back up .
I had friend that knows how to handle a Multimeter and he said there was no power coming in to the bulb , we checked the bulb directly to the battery and it works . We had the dials light up at some point but i disconnected the wire from where it was and can't replicate it
If anyone has any ideas please let me know .
Thanks . |
Nobby the Bastard |
mariust5 |
Posted: 21:57 - 26 Oct 2022 Post subject: |
Nobby the Bastard |
Posted: 22:07 - 26 Oct 2022 Post subject: |
The headlight will only work when the engine is running. It is powered directly from the generator via a fairly complex yet at the same time basic split halfwave charging system. The battery has nothing to do with the headlamp function.
The standard headlamp is a bit pish and it's not uncommon for owners to fit a higher wattage bulb (it should have a 35/35w bulb). This is a bad idea because it overloads the system. They can burn out wiring componants and melt the headlamp lens.
Find the reg/rec. The lighting output is in the yellow wire. Check for voltage between here and earth (either bare metal on the bike or the green wire) with it connected and the engine running. You should get a DC output which climbs to 12-ish volts as revs increase. It will be dirty DC and it will be positive earth (and so will read a negative voltage if you connect the common lead of the meter to earth). Some meters may not read it on the DC setting and need to be set to AC.
If you have 12-ish volts here, the charging system and reg/rec are working. The problem lies upstream (so switch or wiring). If you have no output here, the problem is most likely with the reg/rec. Because it is a split coil, if it's charging the battery and running the engine, it should also be producing a lighting output.
Here's a wiring diagram. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
mariust5 |
Posted: 22:36 - 26 Oct 2022 Post subject: |
Ha , ha , thanks for the reply
I looked to get some original parts but there are brackets and mounts that are missing and the total cost is beyond me at the moment .
About buying new switch i will be in the same boat as these look new just badly wired and prolonged with more wires as not long enough .
Only thing i'd do is the old twist the 2 wires together and tape over . Get rid of the blocks
https://imgur.com/nLXMewP |
mariust5 |
Posted: 22:45 - 26 Oct 2022 Post subject: |
xX-Alex-Xx |
Posted: 23:50 - 26 Oct 2022 Post subject: |
mariust5 wrote: |
You're not too old to get your arse smacked!
Ideally use crimp connectors applied with the correct crimping tool. If you can't do that, use soldered splices covered with shrink tube.
Or the new kids on the block which are heat-shrink, self-solder butt connectors which come with the solder already in them ready to rock. Slide one over the wire, twist them together, set this in the middle and heat it with a heatgun/small blowlamp/lighter. You can buy a huge bag of them for sweetie money on ebay.
https://youtu.be/r7GlDBge_WU
https://i.imgur.com/nLXMewP.jpeg
Yes, that's the reg/rec. With the engine running and it connected, you should be getting 12-ish volts between the yellow and green wires.
If you disconnect it, you should be able to measure a fairly low resistance between the white and green wires of the connector which is the generator coil (probably in the ballpark of 4-10 ohms but I don't know the exact reading for that bike). Shouldn't be zero and shouldn't be very high in the kilo-ohm range. You ought to get an AC voltage output between the green and white wires if you run the engine with the reg/rec disconnected, it will fluctuate a lot, it could also give you a dunt so don't hold the ends of the probes in your bare hands.
If that's the case, charging system is all good.
Let'sa face it though. the wiring is going to be the problem here!
edited to make thread longer, as posting error. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
mariust5 |
Posted: 16:32 - 28 Oct 2022 Post subject: |
Thanks
I'm not much good with Multimeters , i've let my friend do all that .
New development , we've opened the switch to see if something's amiss there and didn't find anything , just my friend said that there is no power coming to it , i take it it needs 12v from the stator . i wish we didn't as next day i've come to it most wires disconnected so i've soldered them back in but now the left hand side indicator doesn't work anymore even if touching the wires together without the switch . The indicator itself is fine as touched some wires and they came on just not from where they should . Off !!
The dash light came on again but gone off and can't replicate it ..
If anyone can tell me how to set up the meter to read those resistances i'd appreciate it please .
This is my meter https://imgur.com/a/Ng7M5zh |
Rob Fzs |
Rob Fzs World Chat Champion
mariust5 |
Posted: 16:50 - 28 Oct 2022 Post subject: |
Looking on youtube it doesn't seem that my meter has a Diode Mode
And this is my friends Meter , seems too simple , not for Automotive i think https://imgur.com/WQsJIII |
mariust5 |
Nobby the Bastard |
Rob Fzs |
mariust5 |
Nobby the Bastard |
Posted: 19:05 - 28 Oct 2022 Post subject: |
https://i.imgur.com/1nFr868.jpeg
Leave the probes in the sockets they are connected in now.
To test normal output, like to see if you're getting power at the bulb or the battery voltage or a voltage output at the reg/rec, set it to 20 in the DCV section.
To test the resistance of the stator windings set it to 200 in the "Omega symbol" section.
To test for an open or short circuit, set it to 200K in the "Omega symbol" section (a reading of 1 usually indicates an open circuit. A very low reading, pretty much the same as if you touch the probes together, indicates a short circuit).
To test the AC output of the stator (between the green and white with the reg/rec disconnected and the engine running) set it to 200 in the ACV section.
EDIT: your mates one is a high quality voltmeter but is just a voltmeter. His will be more accurate, your does more. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
slowasyoulike |
slowasyoulike Scooby Slapper
mariust5 |
Nobby the Bastard |
mariust5 |
The last post was made 1 year, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
