| ChalyChap |
 ChalyChap L Plate Warrior
| Rob Fzs |
 Rob Fzs World Chat Champion
| stinkwheel |
 Posted: 20:09 - 30 Oct 2022 Post subject: |
Cub style forward sloping honda 4t single? It'll probably fire up first kick.
If it were me, I'd drop the oil, clean out the filters (both the gauze and the centrifugal unless you are sure when it was last done), fresh oil, drain the tank (flush it out if there's a lot of yak or stale petrol in it) and run fresh fuel through the carb, clean the points faces and give it a whirl.
I'd kick it over with the plug out a good few time first to get oil circulating (say give it 50 kicks). Maybe treat it to a new plug too.
Then give everything else a good once-over from end-to-end. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Bhud |
 Bhud World Chat Champion
| bikenut |
 bikenut World Chat Champion
| stinkwheel |
 Posted: 13:57 - 31 Oct 2022 Post subject: Re: T |
| bikenut wrote: | All of the above BUT...
Valves ( piston rings, clutches ( two on these from memory, centrifugal ) and brakes etc. can and do stick )
Plug out and lube bore.
Remove valve caps ( check you can get new ones first ) and lube valves as best as possible.
Gain access to flywheel and turn engine over very slowly BY HAND and watch rocker arms and valve tops open and close properly.
If whilst turning the engine over by hand it seems to stop/lock, check for increasing/large gap between rocker arm and valve, a sign of a stuck valve. If you force it at that point ( hand grip on flywheel insufficient for further rotation and damage unless you have 4 wheatabix....) Due to valve inclination, the valves are at an angle, a vee shape/angle, further piston movement towards tdc, WILL BEND A VALVE, and/or break a valve guide.
A stuck valve open can wreck a viable engine in one stroke. You have been worn'd.
Once happy valves open and close properly you can proceed with trying to start the enginr |
There would be a valid argument for saying it's not a lot more work or expense to repair a little sloper honda that just tangled/seized the valves than to do all of the above.
So are you as betting man? With these engines, the short odds are that it'll just start and run like a sewing machine like the intervening 25 years never happened. Outside long-shot on it self-destructing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| A100man |
 A100man World Chat Champion
 Posted: 14:35 - 31 Oct 2022 Post subject: |
Live stream it so we can all share the excitement..  ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion |
| jeffyjeff |
 jeffyjeff World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
| stinkwheel |
 Posted: 16:34 - 31 Oct 2022 Post subject: |
Just to add, the kicking over to get oil circulating is an important step with these motors because they have a hydraulic camchain tensioner which relies on oil feed pressure. You want it being fed with oil before any starting attempts. Happily they also have a pretty effective annular oil pump so they circulate oil quickly and at a good pressure. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ChalyChap |
| Ste |
 Ste Not Work Safe
| bikenut |
The last post was made 3 years, 216 days ago. Instead of replying here, would creating a new thread be more useful? |
