Posted: 17:24 - 11 Nov 2022 Post subject: Fastener name |
I'm looking for an M8 nut that doesn't have a hex on it, just a round cross section on the outside and a socket head on the end. Ideally with a 10 or 11mm OD.
It's for fitting to a particularly tight plate manifold where the hex of the nuts interferes with the jubilee clip.
A bit like a sex bolt but without the flange at the top and ideally a tad thicker... Although I suppose I could always grind the flange off a sex bolt.
I suppose a hex on the top would also work providing it has a plain section (I thought these were called collar nuts, but apparently not).
Just don't know what they're called and if you don't know what they're called, you can't buy them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
jaffa90 |
jaffa90 World Chat Champion
The Artist |
The Artist Super Spammer
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 21:26 - 11 Nov 2022 Post subject: |
Trying to picture what you mean - something like this, but with one end closed, with a socket for an Allen key in?
https://i.accu.co.uk/360/_APC/HTBCN-A2/0_14.png?profile=square
If so, could you use one of these "cylindrical connector nuts" with a socket head bolt in one end? ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Raffles |
Raffles World Chat Champion
Pete. |
Pete. Super Spammer
Posted: 00:01 - 12 Nov 2022 Post subject: Re: Fastener name |
That looks like the very thing, It's not exactly what I was thinking of but is probably better in many ways because the knurling would avoid a lot of fiddling getting it tightened down.
I've currently got JIS M8s on there with the 12mm hex but I even have to rotate them so a flat is facing the middle then fenagle the circlip into the gap between the flat and the manifold.
I found a pictue of what I'm looking for. The origin of the picture calls them Allen round nuts, but that doesn't seem like it's a thing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Pete. |
Pete. Super Spammer
Posted: 07:49 - 12 Nov 2022 Post subject: |
The original items looked pretty much like that, the one above is a reproduction. ____________________ a.k.a 'Geri'
Easy-X |
Easy-X Super Spammer
Posted: 13:10 - 12 Nov 2022 Post subject: |
The most common thing seems to be "sleeve nuts" for furniture:
https://www.ebay.co.uk/itm/224389409851
Quick pass through the lathe?
Also try "barrel nuts" and "cylindrical nuts" optionally with "hex socket head" through Google Images and see if anything jumps out at you ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
BanditsHigh |
BanditsHigh Worse than a woman
Posted: 15:27 - 12 Nov 2022 Post subject: |
It occurrs to me that I could get one of the ones The Shaggy D.A. posted and braze an allen head screw into one end.
I've had some bad luck with those things though, they aren't made of very good metal on the whole because they're designed to join two bits of shitty allthread but I'm sure there will be a supplier who is making them out of something better. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
ZebraDriver |
ZebraDriver Scooby Slapper
Posted: 12:22 - 13 Nov 2022 Post subject: |
As you were folks. It turns out they actually make M8 nuts with an 11mm hex. I found an aviation supplier who does them. I thought 12mm was the working minimum. That extra 0.5mm clearance is all I need. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The Artist |
Pete. |
Pete. Super Spammer
Posted: 12:55 - 13 Nov 2022 Post subject: |
I cou;ld have made you a BSC-M6 or M7 stud that would have taken care of it properly. Aslo, what diameter is the jubilee clip? I have some very thin band ones, yours for free if one will fit. ____________________ a.k.a 'Geri'
Easy-X |
Posted: 14:17 - 13 Nov 2022 Post subject: |
Cheers guys. I think these 11mm hex nuts will do the trick and they are aircraft grade for fitting plate manifolds to rotax aero engines so will be pretty robust.
The trouble with a nylok is the points of a standard 13mm hex foul the manifold. In fact the 12mm ones do too but not as badly so you can set a flat facing the rubber.
A thinner hose clamp would probably help but equally, it's a big thumper with a heavy carb so I want as much support as I can get, the standard ones are notorious for splitting the manifold or spitting the carb off (admittedly, with an Indian manifold, this is a proper Sudco one). I've got the back of the carb supported with a bracket round the air filter too. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 1 year, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
