Farmingstock |
Farmingstock Trackday Trickster
WD Forte |
WD Forte World Chat Champion
Farmingstock |
WD Forte |
Posted: 19:29 - 15 Nov 2022 Post subject: |
If the forks are bottoming, the springs aren't long/strong enough for you. Could have been made with someone lighter in mind, could have deteriorated with age.
They need replacing with stronger ones.
An old fashioned bodge was to add an old valve spring on top of weak springs, this both gives you stronger spring and more preload... but also presupposes you have some old valve springs lying about the place which I suspect most people wouldn't these days. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Farmingstock |
Posted: 21:27 - 15 Nov 2022 Post subject: |
Increasing the preload with a spacer might help if the forks are actually bottoming out. Wont help if it's the spring itself becoming coilbound.
Slices of blue plastic water pipe make good spacers because they are cheap and you can adjust them to whatever length you want quickly and easily. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
A100man |
A100man World Chat Champion
Farmingstock |
Posted: 01:21 - 16 Nov 2022 Post subject: |
From pictures, it's a little aircooled, piston-ported 2-stroke single.
Does it have the original, unmolested airbox and exhaust system?
When was the exhaust last de-coked? Have you tried fitting a new plug? If it's a points ignition, have you checked the gap and ignition timing? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Farmingstock |
Posted: 10:57 - 16 Nov 2022 Post subject: |
If it's a CDI, the timing will be right. Always worth de-coking he exhaust on a stroker that's running badly.
Another thing to check, if it's got them, is that the reed valves are in good order. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Farmingstock |
Farmingstock |
WD Forte |
Farmingstock |
Nobby the Bastard |
Farmingstock |
Posted: 18:51 - 17 Nov 2022 Post subject: |
Nobby the Bastard |
Posted: 19:09 - 17 Nov 2022 Post subject: |
Like I said, it's just a method of burning off residual 2T oil that collects in the exhaust. It'll do next to fuck all against coke deposits. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
Farmingstock |
Posted: 19:36 - 17 Nov 2022 Post subject: |
Nobby the Bastard wrote: |
Like I said, it's just a method of burning off residual 2T oil that collects in the exhaust. It'll do next to fuck all against coke deposits. |
Maybe I should have called Tony Montana?? |
Nobby the Bastard |
Farmingstock |
Posted: 21:54 - 17 Nov 2022 Post subject: |
Also don't discount the possability that the poor wee thing is just worn out and needs a top-end rebuild.
Crank seals are another thing that commonly goes on strokers although it's more common for that to cause poor starting or burning of gearbox oil. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Farmingstock |
The last post was made 1 year, 159 days ago. Instead of replying here, would creating a new thread be more useful? |
