Honda CBF Hornet 02 electrical problems
MrHornet02
PostPosted: 14:39 - 16 Jan 2023    Post subject: Honda CBF Hornet 02 electrical problems Reply with quote
Hello from Sweden, Excuse my English as it's not my native language but I hope you'll understand.
So recently I've had some problems with my Hornet, it started off with my right blinker going very fast, then all of my lights shut off ( except for the headlight)
I got it working again when I switched out the fuse for the headlights but it stops working again when I drive it ( if it's idle it will work)
I've tried checking the cables and I've found no issue there, but I am not experienced in working on bikes.
Any help is very appreciated!
heyhey
Holdawayt
PostPosted: 15:58 - 16 Jan 2023    Post subject: Reply with quote
I've rebuilt a few hornets but the wiring always seems to be intact and working.
All I can think is that you've got an earth cable somewhere that's shorting on a metal component or maybe a wire is loose and is coming away from it's contact when you're on the move.
If you really struggle, a full wiring loom would be easily found on ebay, it'd be a job for an amateur, just take it slowly and take a lot of pictures as you remove the old one.
PostPosted: 16:01 - 16 Jan 2023    Post subject: Reply with quote
I'd start by measuring the voltage across the battery terminals when the engine is running. Lights on and off
I would expect to see no more than 14-14.5V
anything significantly higher say 15V or more would suggest either
a bad rectifier/regulator or a badly grounded one.
On a 20 year old bike I would not be surprised to find poor connections and grounding, so would check and clean as many as I could.
PostPosted: 16:13 - 16 Jan 2023    Post subject: Reply with quote
That's what we call a ground.
There's no need to buy another loom/harness when all you have is a few iffy connections.
You wont find a new one for a 20 year old Hornet it would be hundreds of pounds if you could anyway.
A second hand one may be no better or have other unknown problems of its own
A meter and notepad is all you need
Take readings make notes and learn about your bike as you go
a manual with wiring diagram to refer to would help
MrHornet02
PostPosted: 23:10 - 12 Feb 2023    Post subject: Reply with quote
Thank you guys, i've tried most stuff now and when i removed the relay for the blinkers ( i believe ) it worked, my MC haven't blown a fuse yet, but i'm still wondering why the relay would blow my 10A fuse? Seems a bit odd. https://www.cmsnl.com/honda-cb600f-hornet-2002-2-european-direct-sales_model1638/relay-compwinke_38301kk9952/
heyhey
Zen Dog
PostPosted: 23:48 - 13 Feb 2023    Post subject: Reply with quote
You can get the Honda workshop manual here -
https://drive.google.com/open?id=1d6cBuEX9SwFkZHtypQ1djFBTVf6qcl0P
https://www.motorcyclemanuals.info/motocycles-atvs/honda/
At the back is the wiring diagrams (sadly not in colour).
Current - '94 VFR750FR (Dead), '00 VFR800FI, 2011 CBF125 Previous - '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win (chinese copy of an old Honda design with a C90 engine)
There is a gap of 1 year, 344 days between these two posts...
Perfeedw
PostPosted: 05:43 - 23 Jan 2025    Post subject: Reply with quote
I had a similar problem with my bike last year. My lights would flicker on and off, and I couldn’t figure out what was going on. Turns out, it was a loose connection in the wiring harness that only showed up when the bike was moving, not when it was idle. I also learned that sometimes a fuse can look fine but still be faulty, so double-checking that might help.
If you're still stuck, I recommend reaching out to a local pro. I had a great experience with a utility pole contractor Ottawa, Kanata Utilities, who helped me with some electrical work. They were super helpful, and their advice on how to deal with wiring issues was spot on.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.3 - MySQL Queries: 16 - Page Size: 55.02 Kb
