 2tenjoyer Two Stroke Sniffer
 Posted: 20:54 - 30 Jan 2023 Post subject: NSR125 Help me with the RC Valve |
Hello,
Help me answer these questions, first of all a bit of introduction. I have a NSR125, the RC Valve (the one that moves the flaps), and the RC Valve Control unit. For this to be complete I also need the RC servomotor, the thing that gets the signal from the RC Valve Control Unit to move the RC Valve flaps. Now Imo it’s quite a bit of a hassle to buy, install and then troubleshoot the system.
Am I right about the RC system, did I explain it correctly?
Should I remove it? Please argument your decision.
If I proceed with the removal, will not having the system could cause some problems in the long run? Harm the engine?
I have read somewhere that if I proceed with removing the RC system, I will lose power, the bike probably won’t run ideally and I’ll use more fuel. How much of that is true?
The motorbike will be used for streets, and hooning around the whereabouts. I won’t be using the oil pump, instead I’ll be mixing fuel and oil together in the tank. The bike is getting a bottom end, and top end rebuild. New gaskets, new crankshaft bearings, new piston and its rings. |
 Easy-X Super Spammer
