How do I get inside the headlight assembly? (Fz8)
NutsyUk
PostPosted: 16:13 - 02 Feb 2023    Post subject: How do I get inside the headlight assembly? (Fz8) Reply with quote
Ok some bad news on my new 11k mile bike...
The aim adjustment nut inside the assembly is certainly got a chewed thread. Its loose on that thing :/
But cant figure out a way to get inside to fix it...
It looks like its sealed with a heat rubber glue and has plastic tabs securing it in...
But ive tried with my heat gun to warm it up to pry it off... Just while exposed glue softens the stuff inside the bead seems to stay solid.
The outer plastic appears to show its PP. Which has a melting temp of 160c.
Family wont let me put this in the oven so thats out the question... any ideas?
Lexmoto XTR S 125 Sold!
NutsyUk
PostPosted: 17:50 - 02 Feb 2023    Post subject: Reply with quote
got it in the oven... worked like a charm.
just under 100c 15 minutes...
And yes the 2 plastic nutes that aim the reflector are chewed through...
Why are these plastic!?
Anyway think im going to have to 3d print a metal nut retainer... I have some nuts that should fit these threads...
NutsyUk
PostPosted: 18:24 - 02 Feb 2023    Post subject: Reply with quote
WTF! the bolt rails are M5 but have a nonstandard steeper thread. Not much but only just enough to not take M5 nuts D:
take it back it is M5... just that one bolt has a funky chewed top
PostPosted: 22:22 - 02 Feb 2023    Post subject: Reply with quote
Do you always talk to yourself?
Triumph Trophy Launch Edition
NutsyUk
PostPosted: 22:56 - 02 Feb 2023    Post subject: Reply with quote
Yep Very Happy
Zen Dog
PostPosted: 23:07 - 02 Feb 2023    Post subject: Reply with quote
That does seem particularly crap design, both the glue and the plastic nuts. I think Yamaha would much prefer it if you bought an entirely new light unit at vast expense when those plastic nuts wore through. Bad Yamaha. You've been naughty there.
PostPosted: 10:32 - 03 Feb 2023    Post subject: Reply with quote
..a brave move - what 'Gas Mark' is that?
NutsyUk
PostPosted: 17:18 - 03 Feb 2023    Post subject: Reply with quote
Gas mark tepid!
Youll need temperature control :p
The chassis is PP which has a melting point of 160C according to google. So just under 100c to melt the glue is safe.
NutsyUk
PostPosted: 17:26 - 03 Feb 2023    Post subject: Reply with quote
Even worse, the chrome is very very fragile D:
I had to try some chrome repair, turned into a can of worms Sad Damaged the chrome even more Sad
AAAND the bolts are also chewed up. struggling to get the new nuts back on now Sad
The last post was made 3 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 62.18 Kb
