leeroypenmut |
leeroypenmut L Plate Warrior
WD Forte |
WD Forte World Chat Champion
leeroypenmut |
leeroypenmut |
WD Forte |
leeroypenmut |
Posted: 15:19 - 02 Mar 2023 Post subject: |
Do the headlights run off the battery or on direct lighting where they are run directly from the stator and only work with the engine running?
If it's the latter, it may be they are running on a form of AC, either half-wave or full-wave and you'd need to use the meter on the AC setting to get a correct idea of the actual voltage.
It's always worth checking a previous owner hasn't tried to "upgrade" the bulbs by fitting higher wattage ones, this doesn't work with direct lighting systems, often just makes things worse. I've has success using LED bulbs on my wifes scooter BUT it has a properly functioning charging system AND I know it's halfwave rectified because LEDs wouldn't work on fullwave. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 1 year, 54 days ago. Instead of replying here, would creating a new thread be more useful? |
