Heat loss Calculation
tatters
Exxon Valdez
PostPosted: 23:36 - 15 Feb 2023    Post subject: Heat loss Calculation Reply with quote
I am having a issue working out the heat lost of a building assembly does anyone know of a way to calculate the following? does not seem to be much info on-line to work out for a entire year.
A 258.55m2 area with RSI of 1.40 has a heat loss of 69356.74MJ over a year.
What would the same areas heat loss be if the RSI is 2.84?
PostPosted: 00:42 - 16 Feb 2023    Post subject: Reply with quote
Surface area in metres squared * (temperature differential / RSI) = energy loss in Watts
69356.74MJ per year = 2197.83W (1MJ per year = 0.031688764615413W)
258.55 * ( t / 1.40) = 2197.83
so your temperature differential = 12 degrees Celsius? Sounds about right...
258.55 * ( 12 / 2.84 ) = 1092.46W
1092.46W = 34474.68MJ per year
PostPosted: 01:12 - 16 Feb 2023    Post subject: Reply with quote
Surely the heat loss of any building is 100% of the heat you put into it?
PostPosted: 10:22 - 16 Feb 2023    Post subject: Reply with quote
Over time yes but we're after the rate of heat loss (Watts being an energy per second unit) to give an indication at how well the insulating materials are performing.
tatters
Exxon Valdez
PostPosted: 21:06 - 16 Feb 2023    Post subject: Reply with quote
Perfect thanks
The last post was made 3 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.25 - MySQL Queries: 16 - Page Size: 46.94 Kb
