Yamaha FZ1N Clutch
simonmerrett6...
PostPosted: 18:11 - 18 Feb 2023    Post subject: Yamaha FZ1N Clutch Reply with quote
Good Afternoon All,
I have been changing the clutch on a YamahaFZ1N and cannot get any tension on the cable, I can turn the pull lever with my thumb as there doesn’t seem to be much tension from the pressure plates , any help with why there isn’t much tension?
I have attached a video to show the float on the pull rod
PostPosted: 18:18 - 18 Feb 2023    Post subject: Reply with quote
You've missed a bit out. In that position I would expect it to be a small bearing that goes between the pull rod and the outer plate.
PostPosted: 19:40 - 18 Feb 2023    Post subject: Reply with quote
Part no. 19 if you've mis-placed it. Obviously I've just chosen a random FZ1N because you didn't specify a year.
https://www.fowlersparts.co.uk/parts/6449559/fz1-n-fazer-2d1j-2009-060-a/clutch
Kawasaki Jimbo
PostPosted: 17:33 - 19 Feb 2023    Post subject: Reply with quote
I think that rod in the video looks normal and won’t be secure until the clutch cover is in place. That can be tricky and you’ll need to make sure the slots align on it with the teeth on the push lever
My ‘03 R1 has a slightly different layout with the push lever (1 in Nobby’s diagram) the other way up (cable attachment at the bottom) but there’s a dot on the push lever assembly (26) which you have to line up with an arrow on the clutch cover. Probably the same on yours.
There are several YouTube videos on this topic with respect to the R1. Skip to the relevant section.
https://www.youtube.com/watch?v=gGpP9HBy_nA
https://www.youtube.com/watch?v=Jja3OjQTfHg
The last post was made 1 year, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 17 - Page Size: 40.61 Kb
