Late night thoughts
SpiritMr89
PostPosted: 03:51 - 23 Feb 2023    Post subject: Late night thoughts Reply with quote
Anyone else have random thoughts at night?
Was listening to a thing on yootoob tonight on the Chernobyl Liuidators.
It meantioned about the helicopters, dropping sand, clay, borax(?). On the fire.
Got me wondering, would it have been better to just cap the fire, let it burn, and use filters to catch the radiatoion?
Yes I spend ALOT, of time on my own.
Hello
Raffles
PostPosted: 08:43 - 23 Feb 2023    Post subject: Re: Late night thoughts Reply with quote
Maybe you should spend some of that time learning how to spell Wink
PostPosted: 08:47 - 23 Feb 2023    Post subject: Reply with quote
Cap it with what? Put a filter on where?
PostPosted: 09:54 - 23 Feb 2023    Post subject: Reply with quote
I live in fantasy land at night.
and in the day after a bottle of the Captains finest.
Triumph Trophy Launch Edition
Nobby the Bastard
Harley Gaydar
PostPosted: 10:17 - 23 Feb 2023    Post subject: Reply with quote
This was not a traditional fire. It was bot subject to the usual rules regarding fuel, heat and oxygen.
The radioativity creates heat. The melted core material gets hotter and hotter until it potentially melts it's way to the centre of the earth. It's called the China Syndrome.
In reality what would happen in this instance is that astoundingly hot corium (yes, there is a mineral called corium, the result of nuclear reactors that have melted down) meets fuck loads of ground water, resulting in an even bigger explosion and much wider spread of radioative material.
This didn't happen in the end but it was considered to be such a great risk that miners tunneled underneath the reactor floor in preparation to install liquid nitrogen cooling beneath the concrete base of the reactor building to prevent the heat melting it.
Caping the fire wasn't an option in the first place because it's akin to caping a football stadium size ruined building.
Triumph Sprint ST 1050
Robby
Dirty Old Man
PostPosted: 11:36 - 23 Feb 2023    Post subject: Reply with quote
Also important to remember that all of this was happening in secret, or at least being denied. It's difficult to assemble a football-stadium sized concrete cap, quickly and quietly.
Nobby the Bastard
Harley Gaydar
PostPosted: 11:39 - 23 Feb 2023    Post subject: Reply with quote
It was only secret for about 3 days. The jig was up once it started triggering radiation alarms in Swedish power plants.
PostPosted: 11:50 - 23 Feb 2023    Post subject: Reply with quote
Borax and sand would effectively cap it anyway because it'll fuse in to silica glass from the heat as well as tying up any heavy elements within the glass structure. A bit like when you use it as a flux when you fire-assay precious metals.
I suppose there's a risk of it concentrating the heavy metals in one place under the glass though, increasing the criticality effect. I wonder if adding lead salts to the mix would have encouraged the heavies to form a less rich alloy.
Nobby the Bastard
Harley Gaydar
PostPosted: 11:54 - 23 Feb 2023    Post subject: Reply with quote
The borax absorbs neutrons, damping down the reactions. thats why they chose it.
Not that they actually managed to drop any of it accurately enough to make a difference, though.
Copycat73
PostPosted: 18:54 - 23 Feb 2023    Post subject: Reply with quote
stop drinking coffee after midday .... or mouldy cheese .... Neutral
caveat emptor
Bhud
PostPosted: 23:25 - 23 Feb 2023    Post subject: Reply with quote
I'm gonna think about ancient Egypt again, tonight. Predynastic Egypt, and how they made those precision cut vases. And about what the weathering marks on the the Sphynx mean. Again...
SpiritMr89
PostPosted: 03:34 - 24 Feb 2023    Post subject: Reply with quote
How do you drink cheese?
Hello
SpiritMr89
PostPosted: 03:37 - 24 Feb 2023    Post subject: Reply with quote
Not forgetting the bloke who went to work here.
Set off the alarms, until they tested the carpark (think it was), amd found that was massively high too.
Also, different but same.
The rain that fell here a few days later.
Is there is a link between, Chernobyl and cases of cancer and stuff in that age group, if they were out in it. Particularlly upper body.
Hello
Nobby the Bastard
Harley Gaydar
PostPosted: 08:41 - 24 Feb 2023    Post subject: Reply with quote
As the biggest risk this far away is Iodine causing thyroid cancer. It was a big issue in Ukraine, not really an issue here.
I know a lot of milk was thrown away at the beginning but that was likely caesium, falling onto the grass and being eaten.
PostPosted: 08:57 - 24 Feb 2023    Post subject: Reply with quote
There weren't as many cancer deaths as you'd think, 3940 according to the WHO, about 3% over the baseline. A lot of thyroid cancers but they were mostly treatable. Quite a few deaths from the explosion itself and acute radiation sickness in the initial liquidators.
There were way more excess deaths attributable to the massive social displacement.
https://apps.who.int/mediacentre/news/releases/2005/pr38/en/index1.html
Copycat73
PostPosted: 09:18 - 24 Feb 2023    Post subject: Reply with quote
Does cheese turn into liquid?
The basic building blocks of cheese are milk protein (casein), water, fat, and salt. When heated, the protein molecules break apart and become fluid. Melting, a phase change from a solid to a liquid isn't really happening, the cheese becomes fluid, much like what happens to plastic when it's heated.
on second thoughts ... start drinkin yer bastid Rolling Eyes Laughing Middle Finger
caveat emptor
duhawkz
PostPosted: 10:56 - 24 Feb 2023    Post subject: Reply with quote
Could always ask them next time you're in Pripyat Wink
Islander
PostPosted: 21:21 - 24 Feb 2023    Post subject: Reply with quote
Boron is an extremely effective neutron damper and borate damping systems are part of the emergency control system for nuclear reactors. Boron is also used in control rods for the same reasons.
Considering the initial hydrogen explosion blew the 2000 ton reactor lid through the roof of the containment and core material, graphite blocks, and sundry rubble all over what remained of the roof, various rooms and reactor hall floors, capping it wasn't an option. The primary goal would have been to damp down any reactions, cool the core material down and get the debris contained to limit the escape of radionuclides.
This is what they were faced with
https://upload.wikimedia.org/wikipedia/commons/a/a7/Chernobyl_rubble_and_steam_tanks_overlaid.gif
For scale the lid which can be seen laying at an angle in the middle of the wreckage is 17 metres in diameter and 3 metres thick.
to v or not to v
PostPosted: 21:36 - 24 Feb 2023    Post subject: Reply with quote
i seem to remember news articles about sheep here being born here in Blighty with defects- extra limbs and such, some time after the Ruskie meltdown?
Moto Guzzi V7.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:46 - 24 Feb 2023    Post subject: Reply with quote
The sheep in wales had too high a level of radioactivity for human consumption, no horrific mutations identified. The sheep were tested every three months to check if the radioactivity was within acceptable limits and when radioactivity is concerned these limits are very strict.
Wildlife in the exclusion zone is extensive. Very little signs that wildlife are suffering from the excess radioactivity in the zone are found. Most are animals (and plants) that have particular needs. For example grazers that crop the grass so low they are picking up caesium.
Robby
Dirty Old Man
PostPosted: 23:55 - 24 Feb 2023    Post subject: Reply with quote
To tl;dr the concerns about safety and the realistic impacts.
Nuclear safety guidelines are incredibly risk-averse. The huge exclusion zone around Chernobyl reflects that. Most of the exclusion zone wouldn't actually be very dangerous to live in, you would have somewhat elevated risk of radiation-related illnesses, but not insta-death or weird mutation territory.
If the same level of risk avoidance was used for carbon monoxide, sulphur oxides or nitrous oxides, we wouldn't' be able to drive internal combustion vehicles or have gas boilers in our homes.
PostPosted: 08:57 - 25 Feb 2023    Post subject: Reply with quote
True, and while we have a good idea of the likely effect of high dose exposure (lots of data from the Japan bombings), the understanding of low to moderate doses isn't as well understood.
There's an assumption that the degree of harm is linear but it's probably the case of there being more of a sharp drop-off as dose decreases. There being a point at which the biological repair mechanisms cope with the damage. I remember seeing one study that looked at people who lived in high background radiation areas (like Aberdeen) and high exposure jobs (like airline pilots) and they didn't see a significantly higher rate of cancers in those populations. If I took a piece of Aberdeen granite into Sellafield, it would set off alarms.
Nobby the Bastard
Harley Gaydar
PostPosted: 11:13 - 25 Feb 2023    Post subject: Reply with quote
Some studies seem to indicate a higher background level of radiation is actually preferable. The trouble is, because radiation exposure risk is based on statistical increase of risk of getting cancer, it's hard to prove one way or the other.
RhynoCZ
PostPosted: 18:38 - 25 Feb 2023    Post subject: Reply with quote
Yes, also do not forget that pyramids are on at least three continents (Africa, Asia, South America) and some of them with a plenty of similarities. I'm only talking about those pyramids that we found so far. Now, how's that possible? A pyramid sure is way too specific structure to be a pure coincidence. The builders either could do inter continental travel or maybe even could communicate with each other. The third alternative would be a much more advanced civilization telling the builders all over the world what a pyramid is and what shape should it be. Regardless of all that, it is odd that all those civilizations living so a apart from each other put special emphasis on the pyramid shape. Even when Egyptians ran out of money for more pyramids they still kept the shape in mind when building the King's valley. Thinking
PostPosted: 18:56 - 25 Feb 2023    Post subject: Reply with quote
Or looking at it another way. A pyramid is just a pile with straight sides. If you make a big heap of rocks, you get a cone. If you make a slightly more controlled heap of stones using cut stones laid straight, you get a pyramid.
The last post was made 3 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.33 - MySQL Queries: 14 - Page Size: 129.92 Kb
