Blade fuse holder repair.. help!
PostPosted: 12:19 - 27 Feb 2023    Post subject: Blade fuse holder repair.. help! Reply with quote
Hi all.
FZ 750 has a broken wire on the ignition circuit close to fuse holder.
I wish to push out one of the terminals and re-fix with a new piece of
'good' wire..
But how the f*ck does one extract a terminal (see pic)..?
Ta
jaffa90
PostPosted: 12:57 - 27 Feb 2023    Post subject: Reply with quote
Any good?
https://www.youtube.com/watch?v=79F2roxkXaM
Islander
PostPosted: 12:59 - 27 Feb 2023    Post subject: Reply with quote
There will probably be a small tab that springs out to lock the connector in place when it's pushed home. You'll have to push that tab in somehow.
If all else fails you can get piggyback fuse holders...
PostPosted: 13:59 - 27 Feb 2023    Post subject: Reply with quote
jaffa90 wrote:
Not this time but thanks.
PostPosted: 14:01 - 27 Feb 2023    Post subject: Reply with quote
What I was looking for. It didn't help that I had no glasses with me Rolling Eyes . I took phone photos but noting obvious.
PostPosted: 14:06 - 27 Feb 2023    Post subject: Reply with quote
Yes, you need a small shimming tool to insert into the connector block to push down the tab as you apply gentle traction to the terminal. If you search for terminal extractor tool, you'll find umpteen sets for extracting any number of different terminal types for much cheapness. Although I find a very fine watchmakers screwdriver usually does the trick.
usually look like this, you can see the tabs on the sides.
https://www.vehiclewiringproducts.co.uk/image/cache/catalog/products/normal/20140709_5-1000x1000w.JPG
PostPosted: 14:09 - 27 Feb 2023    Post subject: Reply with quote
Thumbs Up I think I should have will give it a go and report back in a few days.
PostPosted: 14:35 - 27 Feb 2023    Post subject: Re: Blade fuse holder repair.. help! Reply with quote
A100man wrote:
re-fix with a new piece of 'good' wire..
You mean like this?
https://i.imgur.com/IILDwym.png
PostPosted: 15:09 - 27 Feb 2023    Post subject: Reply with quote
I find old hacksaw blades make good 'poking tools' Embarassed
and have made them with a bench grinder and/or Dremel
If the latch doesn't immediately free the terminal, a wee bit of twist often
helps it past the step in the connector body
PostPosted: 15:56 - 27 Feb 2023    Post subject: Re: Blade fuse holder repair.. help! Reply with quote
Ste wrote:
You mean like this?
Murican? Everyone carries .22 shells there I guess.
PostPosted: 15:57 - 27 Feb 2023    Post subject: Reply with quote
Ah yes I once made myself a 'Bogota rake' with one.. Good enough to open the tank of my XJ550..
The last post was made 1 year, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.74 - MySQL Queries: 17 - Page Size: 72.24 Kb
