Fuel Additives
Globule
PostPosted: 19:53 - 27 Mar 2023    Post subject: Fuel Additives Reply with quote
Hi just wondering if anyone uses them to clean injectors/carbs.
Or are they just a waste of money?
Kawasaki Jimbo
PostPosted: 20:02 - 27 Mar 2023    Post subject: Reply with quote
Waste of money unless you’re trying to stop carb-icing (with iso-propanol). I’m not convinced by the ‘stabiliser’ additives (there are better ways to store a bike long-term) and if there is a ‘detergent’ effect on carbs, etc. you’d have to add additive to every tank, raising the cost and possibly reducing economy.
PostPosted: 20:06 - 27 Mar 2023    Post subject: Reply with quote
Never used one on any bike, including the one where I had to scrape the jets out with a needle because basically a whole tank of fuel had evaporated through the carb after the engine seized (not my bike, stood for several years)
PostPosted: 20:12 - 27 Mar 2023    Post subject: Reply with quote
By the time you need to use them, the engine is already beyond help short of a stripdown. You're better off using a tank of Super unleaded every few tanks.
PostPosted: 20:18 - 27 Mar 2023    Post subject: Reply with quote
Get this: petrol is a solvent - I know! it surprised me too Wink - so as long as it flows it pretty much cleans things on its own. Maybe some use with old skool carbs sat about but TBH you'd be better off draining the carb bowl if laying up for a time and if it has been left to varnish up additives are unlikely to avoid a proper strip and clean.
Fuel injection is different. The ECU should prime the things on start up to take into account condensation, ethanol, grime etc. a bit like the cleaning cycle on an inkjet printer. A fucked injector is more likely fucked fucked rather than just gummed up IMHO. Then again I wouldn't be leaving a bike sitting around unused for years and years.
PostPosted: 20:24 - 27 Mar 2023    Post subject: Reply with quote
The ECU won't even prime (pressurise) the fuel rail until you press the starter, it won't do anything special to clean anything. It won't clean or even attempt to clean an injector.
They do get dirty and I did have an instructor at a college demonstrate his kit for cleaning them to me at one point when I was doing voluntary work.
BRUN
PostPosted: 10:27 - 28 Mar 2023    Post subject: Reply with quote
Not on the bike, but at work (car garage) we must have used the Texaco ones 100s of times over the years to get cars through MOT emissions test, they do have an effect
I use the Liqui-Moly stabiliser every winter on our bikes while their stored away
Bike only gets Shell V-Power so no plans to use a cleaning additive for a long long time, possibly never
PostPosted: 10:32 - 28 Mar 2023    Post subject: Reply with quote
Genuinely interested.. which emissions do they help reduce CO2, NO or..?
PostPosted: 10:34 - 28 Mar 2023    Post subject: Reply with quote
The ones used to clean up emissions actually clean the carbon deposits in the engine and exhaust rather than clean carbs/injectors.
You can achieve the same effect by misting water in the intake whilst theengine is running. IIRC Paddy is a great proponent of this technique, alongside the 'Italian Tune-up'.
PostPosted: 14:10 - 28 Mar 2023    Post subject: Reply with quote
I've obviously misread something somewhere...
What's that whirring sound when I turn the ignition on? I thought that was the fuel pump pressurising the system.
PostPosted: 14:30 - 28 Mar 2023    Post subject: Reply with quote
A lot of bikes and cars don't prime the fuel rail. Your may be the exception.
PostPosted: 15:45 - 28 Mar 2023    Post subject: Reply with quote
It usually is, as it's a simple effective method on petrol engines
especially bikes
There may be variations of course but for petrol it makes sense to keep things simple.
tldr:
We know petrol isnt injected at anywhere near the pressure of deisel but as an example, my VW PD deisel lump on the Galaxy has an electric lift pump to supply the injectors, but the high pressure is created by a cam shaft on top of the injectors which also does primary timing.
This is fine tuned ( adjusting the amount of fuel according to various factors) is done by a solenoid valve.
PostPosted: 15:56 - 28 Mar 2023    Post subject: Reply with quote
Much as I love it I don't think the CP2 engine is particularly exceptional it's just I recall the service manual warning:
Cover fuel hose connections with a cloth when disconnecting them. Residual pressure in the fuel lines could cause fuel to spurt out when removing the hose.
PostPosted: 16:15 - 28 Mar 2023    Post subject: Reply with quote
My bike doesn't, so it can't be bumpstarted unless literally just stalled.
Once you press the starter it pressurises the fuel rail and as a result it has to turn over a few times before it starts.
If you cut the engine and then immediately restart it it starts immediately.
There will be some residual pressure some time after it was last used so thats why you need to guard against it. thats not the same amount of pressure as the pressure on the fuel rail when the engine is running.
PostPosted: 19:50 - 28 Mar 2023    Post subject: Reply with quote
Anyway, the point is a good proportion of modern bikes and cars don't even prime their fuel rails before you turn the engine over so won't have gone through a injector cleaning cycle,even if they could because a specific fluid that isn't petrol or diesel is needed to do so.
Kawasaki Jimbo
PostPosted: 20:04 - 28 Mar 2023    Post subject: Reply with quote
“… and an extra £20 for the magic mix.”
Me too. Do you just chuck it in the tank and run the motor for a bit? Seems unlikely to work.
PostPosted: 20:12 - 28 Mar 2023    Post subject: Reply with quote
If that's the case I can't see these additives doing much of anything. Whatever you tip in the tank is going to take a while to get through the fuel pump, pipes and injectors.
PostPosted: 20:34 - 28 Mar 2023    Post subject: Reply with quote
I use Yamaha Fuel Stabilizer when I park the bikes for several months. About a cap full to a brimmed tank of fresh petrol. 98RON
Globule
PostPosted: 12:19 - 29 Mar 2023    Post subject: Reply with quote
I ask because I bought a scooter (Honda Pantheon 125) and apparently it has fuel injection. 20 years old, but it's only just done 4K miles!
Only ever had carbed bikes before, my Blackbird has carbs and I'm used to them, but FI is new to me. (I know I'm really old fashioned).
PostPosted: 12:43 - 29 Mar 2023    Post subject: Reply with quote
Does this work with Suzukis?
PostPosted: 13:30 - 29 Mar 2023    Post subject: Reply with quote
Does it run? If yes, ride it. If not, fix it. Fuel additives will do nothing.
The last post was made 1 year, 18 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.05 - MySQL Queries: 17 - Page Size: 115.24 Kb
