CB600 F4 Hornet - Front fork leaking oil
Blunet600
PostPosted: 15:53 - 15 Apr 2023    Post subject: CB600 F4 Hornet - Front fork leaking oil Reply with quote
Hi, i am after some advice and/or confirmation. I had an off on my hornet around 2 years ago just as covid hit. The side was all scratched and the mirrors and foot pegs broke but the bike came off well and seemingly had no major damage.
Fast forward 2 years and the left fork is leaking oil, so i get the seals changed and then about a year later they are leaking again. I get them changed again and the next day there is oil leaking out still... so the mechanic changes the seals again for me and said if it leaks again then he suspects it could be a damaged pipe.
( Could this have been from the off i had... i hit deck on a bend and the bike slid on its right side down the road)
The fork did start leaking again the next day, so i am now looking at getting a new pipe but wondered if anyone had any other suggestions or advice before i went and paid for a new pipe (which is not cheap).
Thanks for the time all. Any help or advice is appreciated.
Honda - Power of Dreams - NSR 125R - Hornet 600
PostPosted: 16:04 - 15 Apr 2023    Post subject: Reply with quote
I would have thought if a stanchion was so bent oil was pissing out the handling would be off as well Thinking
How much is leaking out exactly? A picture would help if you can manage it.
Pete.
PostPosted: 16:23 - 15 Apr 2023    Post subject: Reply with quote
Bent stanchions are easy to check, just roll them on a flat surface, or roll them together. If they are bent you will know it right away.
As for the seals, probably if they are leaking and there's no sign of scuffing on the chrome, then they were poorly installed.
a.k.a 'Geri'
Blunet600
PostPosted: 16:29 - 15 Apr 2023    Post subject: Reply with quote
A lot comes out, after riding for 20 mins or so, the fork is wet all round with oil. The seals have been replaced now 3 times. by 2 different mechanics... i had thought the same that maybe it had been installed poorly but both are decent bike mechanics with a lot of experience. i havent taken the pipe out but given what you guys are saying i will take it the garage before i order a new one and see if they have any ideas. I cant say i have noticed the handling being noticeably off... other than my own anxiety on bends these days....
will get the covers off soon and get some photos.
PostPosted: 16:42 - 15 Apr 2023    Post subject: Reply with quote
If there's no visible surface damage and no visible bend, it's probably not the stanchion. Probably needs new bushings. if you've got play in the bushings, the seals will fail. I just routinely replace the bushings if a set of seals goes with no obvious cause.
Also my experience of aftermarket seals is very poor. I just buy honda seals now because the extra cost is worth not having to do them again a couple of months later.
Robby
Dirty Old Man
PostPosted: 20:44 - 15 Apr 2023    Post subject: Reply with quote
Same. I've never had a set of aftermarket seals work, and I've never had a set of genuine seals fail.
You can check the fork tube for flatness by rolling it on something flat. It doesn't need to be micron-perfect, everything flexes a bit and the seal normally allows for this.
PostPosted: 21:34 - 15 Apr 2023    Post subject: Reply with quote
Either, the seals are being damaged on install or the wrong seals for the cylinders, or s4ite quality/non-OEM.
PostPosted: 22:54 - 15 Apr 2023    Post subject: Reply with quote
If it's on its third set of seals, I'd say that if the bushings weren't buggered to begin with or have already been replaced, they will be now. Either that or they didn't actually dismantle the forks to change them and as such the bushings haven't been checked.
I would also say that just because a job was done by a motorcycle mechanic, doesn't mean it was done properly...
When I did the forks on Mrs stinkwheels CBR600FY, which I imagine are a similar age and design to your ones, the bushings were in there tight. They actually over-rode one another on one fork leg and took me a very long time to remove. Both sets of bushings were damaged after removal anyway (even the one that came right apart) so I replaced them and used aftermarket seals, both of which leaked a few months later. I then fitted Honda seals which have been fine.
Blunet600
PostPosted: 12:09 - 20 Apr 2023    Post subject: Reply with quote
Thank you for all your help. I have ordered new bushings and seals direct from honda. Hopefully they can all be replaced properly and i can out on the bike again.
PostPosted: 13:11 - 20 Apr 2023    Post subject: Reply with quote
to add.. I'd have thought most forks with accident damage will bend at teh yoke clamp leving the travle area unaffcted for teh most part..
Bushings seems the answer -not that I've got any experience in that - my GT250 doesn't appear to have any Confused
P.
PostPosted: 21:04 - 20 Apr 2023    Post subject: Reply with quote
How are the bushes looking?
I stripped my CBF last weekend as one started to leak a fair bit and one of the bushes was....well, not in great nick. Think its teflon or similar? It was basically gone around 3/4 of it and looks like they havent been touched in a while. Other one looked pristine and has no leaks at all.
Was always told to replace while its apart.
Blunet600
PostPosted: 21:53 - 02 Jun 2023    Post subject: Reply with quote
Update on the fork situation. Turns out is was a tiny chip on the stanchion which was causing the seals to leak. Ended up having to get a new stanchion.... Confused
Got the guy to replace the bushes anyway as i had a new set of honda ones.
Bike is all good now.
Right fork began leaking yesterday which sent me over the edge...fml.
Luckily though it turned out to just to be a bit of dirt. Fished that out and now it's golden.
Thanks for all the advice guys. Muchly appreciated.
P.
PostPosted: 10:06 - 04 Jun 2023    Post subject: Reply with quote
I ended up buying new forks. Some of the mess inside one of mine was just daunting to look at.
Cost the same as bushes, seals and oil so hey Very Happy
The last post was made 1 year, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.18 - MySQL Queries: 16 - Page Size: 82.31 Kb
