kawakid |
kawakid World Chat Champion
Posted: 23:30 - 14 May 2023 Post subject: Battery Issues - YBR125 |
Hi,
Not my bike, its my sons and I think I might know the answer.
Middle Son 19, bought a YBR to learn on.
Last week, he travelled to work (4 miles), then to his girlfriends (16 miles) and back and his bike failed to start after his return Quick charge on battery and all was fine.
The battery is a Yuasa and no more than 2 months old. (We swapped to this as his battery conked out, during a winter ride).
Looking at his battery with a multimeter, it is getting a charge and the reg/rec seems to be doing its job, giving no more than 14v.
I've put the multimeter to amps and I can't see an obvious leak.
Tbh, he's had this issue since around the time he got the bike, but it was cold in winter and he's just got used to topping his charge up. To the point his(my) trickle charger goes with him.
Now the only thing I can think and I will swap it out, is when he got his bike, we swapped his dull bulb for an Osram (H4).
Other things of concern, his journey to work is really short like 4 miles.
The battery is tiny.
There is heated grips, but he isn't using them, the multimeter didn't detect a leak. (Though i've not checked for a relay)
Any help/pointers appreciated. ____________________ I've a twin and a 4. |
WD Forte |
WD Forte World Chat Champion
Posted: 08:00 - 15 May 2023 Post subject: |
An ammeter with it running would be useful to see what it's drawing/putting in. Most multimeters have a 10A setting and input. Be an interesting exercise to plug it in in place of the main fuse and see what it's drawing with the engine off and ignition on then with the engine running. Then plug it into the output for the reg rec and see if it's pushing out more than it's drawing.
Shouldn't pop the meter fuse and if it does, if it's drawing more than 10A and you've found the problem. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Robby |
Robby Dirty Old Man
kawakid |
MCN |
MCN Super Spammer
kawakid |
Posted: 12:49 - 14 Jun 2023 Post subject: |
Hi,
Just an update on this, firstly thanks for all the help.
I thought I was going mad, I tested for loss using a multimeter, but it wasn't showing as any drain. I even had a mate who is a spark make sure, i'd connected it correctly.
I then considered taking the bike to someone who knows what he's doing, rather than a 50 year old IT guy (moi).
In the end, the bike failed to start after being on charge over night.
I cranked it over and on the mulit meter, DC volts went from around 12 to 7.
Yup a dead battery.
Now this battery was brand new Yuasa and purchased from a very reputable Car Parts place.
They tested it and confirmed it was fubar, ultimately a new battery has fixed it.
The battery is really small, the other thing that concerned me is that the acid had already been added. (Perhaps something to do with recent acid attacks).
Not sure what to think, I just hope he can soon pass his test (A2) and move on to something decent and more supportable.
Once again thanks. ____________________ I've a twin and a 4. |
A100man |
A100man World Chat Champion
Posted: 14:00 - 14 Jun 2023 Post subject: |
kawakid wrote: |
I think so.. Only gel batteries by mail order these days whereas you used to be able to get dry battery plus plastic acid filler... ____________________ Now: A100, GT250A, XJ598, FZ750
