FZ1 Fazer 2010 overheating
Andy_Pagin
PostPosted: 21:04 - 21 May 2023    Post subject: FZ1 Fazer 2010 overheating Reply with quote
I've never had overheating problems before. Bike hasn't been used for about three months. Went out last night for a run, bike behaved completely normally, nice ride no traffic, moving more or less the whole time. Got home, while I was getting the bike down the side ally the temp warning light came on, the gauge flashing 120c.
Tonight I checked the expansion bottle, low but not dry, filled it up, started her up, temperature rose steadily to 100c when both fans came on as expected, temperature continued to rise steadily, very slowly to 120c.
Top and bottom hoses feel hot, top of radiator feels cooler than the bottom.
Oil looks ok, no signs of coolant leakage, bike runs fine.
What should I be checking next?
PostPosted: 21:25 - 21 May 2023    Post subject: Re: FZ1 Fazer 2010 overheating Reply with quote
The temp gauge?
Andy_Pagin
PostPosted: 22:38 - 21 May 2023    Post subject: Reply with quote
Forgot to mention something odd, when I started the bike and let it idle the temperature gauge showed 'Lo', and stayed that way until I revved it after about thirty seconds when it changed to 47c, ie. there was no gradual increase in the reading until I revved it the first time.
Robby
Dirty Old Man
PostPosted: 23:11 - 21 May 2023    Post subject: Reply with quote
Assuming the gauge is accurate and the system is full, then it isn't managing to dump heat.
First thing is to externally clean the radiator, check if it's dirty enough to stop airflow getting through or has lots of bent fins.
If the rad looks good, next place I would consider is the water pump, checking for a worn, cracked or sheared impeller blade.
PostPosted: 05:06 - 22 May 2023    Post subject: Reply with quote
Erratic temperature indication could be low coolant. Cold when not coola t on it, then when hot coolant splashed on it shows hot.
Even though the spansion tank look full, doesn't mean the radiator is full.
Open the rad pressure cap and check.
There would also be a puddle of coolant on the floor/path/slabs/monoblock under its parking spot. Where the missing coolant gathers.
For a poached water pump, before you invest in a big bit, check for flow.
There is sometimes a bleeder plug near the top of the water pump/area of pump. Crack the plug open until you see a drip of coolant.
Start the hoowur, and see if the drip becomes a stream or drips faster. That says there is flow. (Pumps only create Flow. Restriction creates pressure. )
Other thing could be a phahed temp sensor.
Some equipment use one sensor for all. Gauge and fan control. Some equipment has two. On for gauge one for fan.
You will loose coolant to replace them either way.
The trick with cooling system troubleshooting, is to try to not have to phaph with draining, filling fecking coolant if not necessary. Cool
If the system need coolant added, squeeze the hoses to help force any trapped air out.
jeffyjeff
PostPosted: 09:24 - 22 May 2023    Post subject: Reply with quote
After checking the radiator for obstruction an ensuring proper fan operation and air flow (I've seen fans installed backwards so the cup is not biting air), I would check for causes of insufficient coolant flow. Bad thermostat is probably the most likely culprit, followed by a clogged radiator. Water pump impellers can erode due to cavitation, but other causes are more likely.
Fan operation at idle should pull down your coolant temperature within a minute or so, temperature still climbing after fans turn on suggest the engine will overheat severely when underway. As stated above, make sure cooling system is filled to capacity.
xX-Alex-Xx
PostPosted: 00:06 - 23 May 2023    Post subject: Reply with quote
Check the easy stuff first. Coolant full, replace radiator cap as it’s cheap, then look at the thermostat.
DILLIGAF
jaffa90
PostPosted: 01:27 - 23 May 2023    Post subject: Reply with quote
This with expansion tank half full.
PostPosted: 07:43 - 23 May 2023    Post subject: Reply with quote
Filling the expansion tank doesn't fill the radiator. Filling the radiator fills the radiator.
PostPosted: 10:01 - 23 May 2023    Post subject: Reply with quote
My spelbot on my phone makes me look like an idiot.
I type it, I see wot I typed. I submit.
What is submitted gets changed between send and read.
It's Driving Me Nuts.
Andy_Pagin
PostPosted: 20:37 - 28 May 2023    Post subject: Reply with quote
I assumed you'd been on the falling down water Laughing
Thanks for the advice though.
PostPosted: 00:12 - 29 May 2023    Post subject: Reply with quote
My guess is stuck thermostat or bad pump
Andy_Pagin
PostPosted: 17:46 - 02 Jun 2023    Post subject: Sorted! Reply with quote
Well I fixed it, the worst kind of fix, where you don't actually find out what the problem was.
First I garden-hosed the outside of the rad, can't say much muck came out and the water gushed through fairly well.
Next checked the water level at the rad cap. It wasn't brim full, so I added some coolant, about 60ml. Cap looked in good order, no signs of coolant having blasted out.
Started her up, nice steady increase in temperature at the gauge. Took noticeably longer to reach 100c. Fans kicked in, went up to 102c then drifted slowly down to 94c. Cycle then repeated ...
So now I'm going to have to watch the bloody temperature gauge like a hawk on every ride. Rolling Eyes
PostPosted: 20:38 - 02 Jun 2023    Post subject: Reply with quote
shall we start insulting you now then over it ?
Mr. Green Mr. Green Mr. Green
Walloper doesn't act like a complete cunt all the time.
PostPosted: 22:01 - 02 Jun 2023    Post subject: Reply with quote
I never said I wasn't a complete cunt.
PostPosted: 22:17 - 02 Jun 2023    Post subject: Reply with quote
dave001 wrote:
your not useful enough to be a cunt Wink
I should really thank you for confirming that I'm not a cunt.
PostPosted: 22:27 - 02 Jun 2023    Post subject: Reply with quote
No because that would take attention away from you and nobby who are getting on really well right now.
Wub
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.2 - MySQL Queries: 17 - Page Size: 113.25 Kb
