Motorcycle Overheating after Coolant Change
10kovako
PostPosted: 19:22 - 29 May 2023    Post subject: Motorcycle Overheating after Coolant Change Reply with quote
Hey!
So I’ve changed my coolant in my Suzuki GSF 650, flushed it, and got rid of any air (to my best knowledge).
Then the issues started happening. First I noticed after the 1st ride the overflow bottle filled to the max, then I noticed that the coolant started leaving the overflow tube after rides, and now the engine overheated, and after checking the bottle was nearly empty, and had to top up the radiator with 300ml coolant. Could this be the dreaded head gasket issue? Or not, as the coolant only leaks from the tube after I’ve stopped riding.
Any thoughts would be greatly appreciated!
Let’s do this
PostPosted: 19:30 - 29 May 2023    Post subject: Reply with quote
If it were behaving normally before you changed the coolent it won't be the head gasket.
There's exccess air in the system. Take the filler cap andleave it off after starting WHEN IT's COLD. Let the excess air bubble out and top up before it gets hot.
Triumph Sprint ST 1050
Kawasaki Jimbo
PostPosted: 19:40 - 29 May 2023    Post subject: Reply with quote
Also check that the radiator fan comes on.
10kovako
PostPosted: 20:08 - 29 May 2023    Post subject: Reply with quote
I bought the bike about a month ago, so hoping it’s something I did! I’ll try that again tomorrow with it being cold.
Also yes, fan kicks on. The temp warning light also goes on but I’m guessing that’s from the reduced level of coolant!
Let’s do this
10kovako
PostPosted: 20:09 - 29 May 2023    Post subject: Reply with quote
Also, I thought that the reason for the overflow reservoir is for the bike to automatically adjust coolant amount, this getting rid of trapped air? Or am I misunderstanding? Would not enough coolant explain the reservoir bleeding it’s coolant out too?
Let’s do this
PostPosted: 20:18 - 29 May 2023    Post subject: Reply with quote
It's an expansion chamber. It's supposed to allow for the expansion of a liquid.
If there is air in the system the air will expand a lot more than the liquid will and at a lower temperature, forcing excessive amounts of coolant into the chamber.
10kovako
PostPosted: 20:35 - 29 May 2023    Post subject: Reply with quote
Understood! And it can reach a point of it expelling all of the liquid from the chamber?
Many thanks!
Let’s do this
PostPosted: 20:57 - 29 May 2023    Post subject: Reply with quote
The coolant bottle is effectively an overflow. If you fill it, you're going to have a coolant leak.
It's also common to get an air lock after you change coolant, riding it will often 'burp' the system so the air is expelled. I'd open the radiator cap and see if there is any air in the top of the rad. If it's now full, and your expansion tank just has a little bit of coolant in it up to the minimum, ride it again to see if it overheats.
10kovako
PostPosted: 23:55 - 29 May 2023    Post subject: Reply with quote
Gotcha, but can an air lock expel the coolant that’s already in the bottle? As it had more in it before I noticed the leak, not basically empty. Or did I have such a significant air lock that it sucked some of the coolant from the bottle into the system itself?
Let’s do this
PostPosted: 08:00 - 30 May 2023    Post subject: Reply with quote
If it burped a big air bubble out, it would have to go somewhere first and that's into the expansion tank. The system has to be under pressure for the radiator cap to be opened against its spring which would allow coolant to flow both ways between the expansion bottle and the radiator. That't wont happen properly while there's air in the system because air is compressable.
It MIGHT be your head gasket, it's possible a bit of crud was all that was preventing if gassing through and the flushing dislodged it but as above, I'd refill and take it for a bit of a run and see if it's still doing it. If the gasket's gone, the gasket's gone. If it hasn't, you're fine.
Another wee test is to feel one of the coolant hoses as you rev the engine. If it goes hard as you rev it, that would be a bad thing.
PostPosted: 10:49 - 30 May 2023    Post subject: Reply with quote
Radiator pressure cap off.
Fill the radiator until the level of coolant is at the top of the radiator filler neck/pressure cap flange.
Squeeze the bottom hose and top hose (if accessible) that should help to dislodge any air trapped in a corner somewhere. Or as Nobbers suggested, start the engine, the pump will circulate coolant around the system and dislodge air. But it might also Vomit it out over your good slacks.
Top up the radiator and repeat until you cannot top up anymore.
Radiator cap on. Make sure it is twisted over the detent to lock it in place too.
Adjust the expansion tank/bottle to the max level. Fitt the cap.
Run the engine until warm and the thermostat/regulator is fully open.
Raise the rpm blip blip to push the coolant around.
Shut off.
Check the level in the expansion tank.
BMW FYI recommend filling the cooling system via a vacuum device.
Coolant is sucked into to system from a container. (Physics l: Air pumped out of the system by the vacuum pump is relaplaced by coolant, which is pushed into the void by atmospheric pressure.
The vacuum is applied after the system is full.
The vacuum causes trapped air bubbles to expand in the lower than atmospheric pressure, when they get bigger they join up with other big air bubbles and can then roll out of the system easier.
The vacuum is released and the expansion tank topped up.
Vor Sprong Dork Teqnique.
10kovako
PostPosted: 19:39 - 31 May 2023    Post subject: Reply with quote
So, I’ve done as everyone has advised and ran with cap off etc.
Topped up to the max. No bubbles when revving, all seems good.
Went out for a hard ride, let the bike cool for a few hours, opened up the cap and water wasn’t to the top, but the expansion tank was definitely more full than before.
Did I let the bike cool enough for it so suck the coolant back up, or is there a leak in the return hose, or a faulty radiator cap?
Or is that normal?
Let’s do this
10kovako
PostPosted: 15:31 - 01 Jun 2023    Post subject: Reply with quote
Upon inspecting the hose at the bottom of the expansion bottle, I’ve found a little crack, could this be the cause? Coolant isn’t leaking out, but it could prevent vacuum from being made - thus allowing the coolant to dump into the bottle, but not be sucked back up?
Many thanks,
Kostya
Let’s do this
PostPosted: 16:42 - 01 Jun 2023    Post subject: Reply with quote
You're now looking for problems that aren't there. Ride it.
10kovako
PostPosted: 17:23 - 01 Jun 2023    Post subject: Reply with quote
I rode it a few times, and after waiting for the bike to cool down, the coolant level dropped after every ride. And after stopping at home, it always pissed some out after stopping from the overflow tube. Doesn’t happen when riding, only when stopped and about to switch off.
Topped up the radiator every time. So it’s transferring it to the expansion bottle, where it gets overfilled and purges it, thus loosing coolant.
Like I said, there are no bubbles when revving, water is pumping well.
Let’s do this
PostPosted: 17:33 - 01 Jun 2023    Post subject: Reply with quote
In that case you are overfilling it. When you turn it off,all that heat in the engine is seeping into the water that is no longer being cooled so the coolent expands.
The small gap at the top of the radiator is probably because a vacuum forms whilst you are riding and when you take the cap off when cold you are letting air in.
10kovako
PostPosted: 18:15 - 01 Jun 2023    Post subject: Reply with quote
But that’s the strange thing, if I was overfilling, surely the engine wouldn’t overheat? The cap is a strange one, it’s actually under the tank not in the radiator, by the thermostat. There’s definitely still an air gap. Is this normal?
Let’s do this
10kovako
PostPosted: 18:17 - 01 Jun 2023    Post subject: Reply with quote
Ran another test again, and under the fuel tank, when I take off the coolant cap, the thermostat seems to allow water through to fill the radiators, and when a little warm the level appears full. As soon as I switch off the level drops again, so strange!
Let’s do this
PostPosted: 18:23 - 01 Jun 2023    Post subject: Reply with quote
You do realise there is a pump that will raise the level when the engine is running and it will lower again once you turn off the engine? Thats what pumps do...
10kovako
PostPosted: 19:43 - 01 Jun 2023    Post subject: Reply with quote
With all of the emphasis on bleeding the system and making sure there’s no air in it, then surely the pump is just to circulate the coolant already in there?
Shouldn’t raise/ lower it?
What I was mentioning is that it seems the radiator empties itself when the bike is switched off.
Let’s do this
PostPosted: 19:47 - 01 Jun 2023    Post subject: Reply with quote
if you have the cap off then it will raise the level. Thats why you were cautioned about water coming out of the filler hole onto your slacks.
Quite frankly, if you keep faffing with it and don't just ride it and see if it overheats then you're a lost cause.
Stop filling it up, ride it and see if something dramatically goes wrong.
If the expansion bottle overflows, wait until it cools down and then ride it again without topping it up.
Does it happen again?
jeffyjeff
PostPosted: 19:53 - 01 Jun 2023    Post subject: Reply with quote
A functioning radiator cap will maintain pressure in the cooling system, allowing excess volume (due to coolant expansion when hot) to flow into the surge tank/expansion tank. As the engine cools, the radiator cap will maintain an airtight seal, and the coolant in the surge tank will migrate back into the radiator. Your symptoms suggest the radiator cap is allowing air into the radiator upon cool down. I suggest replacing the cap. The STANT 11233 is an aftermarket cap that works on many japanese bikes, and costs a fraction of the OEM cap. Wink
PostPosted: 20:00 - 01 Jun 2023    Post subject: Reply with quote
If the radiator cap is letting air in when the bike is cooling, how is it maintaining pressure when the engine is hot? Bear in mind the whole point is that the pressure allows the coolent to go over boiling point and steam would get out the cap just as easily as air gets in.
It's not like the cap gets worn out by use....
jeffyjeff
PostPosted: 20:22 - 01 Jun 2023    Post subject: Reply with quote
The radiator cap contains two valves and two springs. A pressure valve backed by a high pressure spring, and a vacuum valve that seats on pressure and unseats against a very lightweight spring on cool down. This action allows fluid from the surge tank to migrate back into the radiator.
https://www.freeasestudyguides.com/engine-radiator-cap.html?utm_content=cmp-true
I respectfully submit that the radiator cap does indeed incur wear over numerous heat cycles.
jeffyjeff
PostPosted: 21:20 - 01 Jun 2023    Post subject: Reply with quote
A leak in the surge tank tube above the coolant level could cause air to migrate into the radiator even if the radiator cap is functioning properly.
The last post was made 3 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.18 - MySQL Queries: 16 - Page Size: 137.24 Kb
