Compo |
Compo Nova Slayer
Nobby the Bastard |
Compo |
Compo Nova Slayer
Kawasaki Jimbo |
jeffyjeff |
jeffyjeff World Chat Champion
Compo |
Compo Nova Slayer
Kawasaki Jimbo |
Compo |
Compo Nova Slayer
Compo |
Compo Nova Slayer
Nobby the Bastard |
Pete. |
Pete. Super Spammer
Posted: 19:52 - 15 Jun 2023 Post subject: |
The wire takes power from the front and rear brake light switches, which take power from the 10A fuse in the junction box. That fuse takes it's power from the brown wire out of the ignition switch which itself takes power from the 30A fuse on the starter relay via the white wire.
If you're getting only 9.8v at the switch then the feed is at fault. Pull the fuse and check for corrosion. If you're getting only 9.8v at the fuse pull the 30a fuse at the starter relay. If you're getting 12v there plug the fuse back in, check again the fuse box and if it's still 9.8 volts un-plug the rectifier from the loom and check again. If you're now getting 12v the rectifier is fucked. ____________________ a.k.a 'Geri'
Kawasaki Jimbo |
Compo |
Compo Nova Slayer
Compo |
Compo Nova Slayer
Posted: 13:38 - 17 Jun 2023 Post subject: |
All sorted lads brake lights and the alarm
Corroded 30 amp fuse. MOT Monday.
thanks Pete |
