Two stroke backfire when cold
PotatoHead202...
PostPosted: 22:52 - 02 Jun 2023    Post subject: Two stroke backfire when cold Reply with quote
Managed to get the CZ through its MOT today.
However, on the way home it broke down 3 times (gurgled, bogged and died). Pretty certain this was down to very stale fuel that I stupidly used to top it up with (absolutely reeked). Washed the tank out, cleaned the (dirty) carb and managed after a number of kicks to get it running again. I'm getting what I'd describe as popping/backfire at idle for the first 20 or 30 seconds when cold. If I get on and ride it disappears and doesn't come back. If I normally start from cold it'll start with about 2 kicks.
Any ideas? Runs fairly well apart from this. I do have a suspected leak at where the exhaust joins the head and can see a bit of fuel leaking from the carb rubber to airbox join.
Again, this is basically a brand new engine and carb now with less than 30 miles on it. It has that crappy jikov carb so very basic. Getting a good spark and again this only happens when cold.
Honda VFR1200F, Honda CBF500 ABS, CZ125 now CZ175
PostPosted: 10:54 - 03 Jun 2023    Post subject: Reply with quote
crankcase is full of manky petrol and oil. My advice? Thrash it hard until it stops doing it.
ThatDippyTwat
PostPosted: 14:10 - 03 Jun 2023    Post subject: Reply with quote
This. Just did it with the KDX. Was smoking like a bastid and surging a touch until I thrashed it up a good 30% incline.
PotatoHead202...
PostPosted: 15:22 - 03 Jun 2023    Post subject: Reply with quote
Aha, glad to hear that. I'll give it a dam good thrashing tomorrow!
PostPosted: 17:10 - 04 Jun 2023    Post subject: Reply with quote
The spade terminals on the ignition coil can make a very poor/intermittant connection despite seeming tight so they are worth a try. A duff condenser could also cause issues like you describe.
As I remember they don't like resistor plugs either.
PotatoHead202...
PostPosted: 11:33 - 05 Jun 2023    Post subject: Reply with quote
Thanks, I'll have a look at the terminals as well just to be sure.
New exhaust bolt (wider flange) seems to have cured the backfire/popping. Have to be very careful not to flood it when starting from warm. The clutch is still the bane of my life at the moment - either too tight or too lose so it creeps in gear. Gearbox has to be the worst I've ever used, have to be really deliberate with changes or it either won't go in or will hit neutral, and that's with brand new selector forks and cam plate. Still could be worse, could slip out of gear.
Did get it up to about 60 yesterday though, gradually freeing up a bit.
PostPosted: 11:43 - 05 Jun 2023    Post subject: Reply with quote
Presumably you've added the massively over-reading speedo onto the list of things to repair.
PotatoHead202...
PostPosted: 14:51 - 05 Jun 2023    Post subject: Reply with quote
Tbf I was neck and neck with the other traffic on a fast A road that usually travels at that spped. I was somewhat shocked that I managed two (slow) overtakes on it!
blurredman
PostPosted: 12:46 - 20 Jun 2023    Post subject: Reply with quote
4 speed ? A lot of 4 speeds are like this.
Current: 1973 MZ ES250/2 - 17k. , 1979 Suzuki TS185ER - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.08 - MySQL Queries: 17 - Page Size: 62.95 Kb
