Vibration
DaddyStu
PostPosted: 13:27 - 04 Jun 2023    Post subject: Vibration Reply with quote
Getting some seat vibro at speed following chain adjustment. The scale reads the same both sides and the sag(?) is within suggested range.
It's not severe but my prostrate has lodged a formal complaint.
Anything else I should be checking?
Daddystu
Islander
PostPosted: 13:36 - 04 Jun 2023    Post subject: Reply with quote
Wheel alignment?
PostPosted: 16:59 - 04 Jun 2023    Post subject: Reply with quote
Front sprocket securely bolted on?
Sprocket carrier bearing in good order?
sickpup
Old Timer
PostPosted: 17:54 - 04 Jun 2023    Post subject: Reply with quote
Check for stiff links and if your rear sprockets is actually round.
sickpup
Old Timer
PostPosted: 19:02 - 04 Jun 2023    Post subject: Reply with quote
dave001 wrote:
bet you dint look for the tightest spot on the chain before adjusting
Would that be caused by an out of round rear sprocket? Think about it...
DaddyStu
PostPosted: 19:27 - 04 Jun 2023    Post subject: Reply with quote
Thanks all. Yes I checked the chain over when i relubed it so sure its not a stuck link. Not sure about the front sprocket - to check would require some disassembly so will check when i've some time.
Wheel alignment would seem the likely culprit. I was under the impression doing up the adjusters the same on both sides accounted for that. Web-search would have me using strings and tubes to check - or I could wait until the service due this month.
Daddystu
PostPosted: 23:47 - 04 Jun 2023    Post subject: Reply with quote
Feck all info so making guesses.
I'll assume your 'sag' is free play, but how much have you allowed it?
and how/where did you measure it?
I'm also assuming its pretty new so has low-ish miles
I'm also going to assume/guess as it is a sudden symptom,
you've just over tightened it a bit.
I'd try backing it off half a turn on each adjuster, maybe even 1 complete turn as I'm ( still) guessing the adjusters have 8mm threads and will have pitch of 1.25 to 1.5mm so wont slacken the chain very much.
DaddyStu
PostPosted: 00:09 - 05 Jun 2023    Post subject: Reply with quote
Newish yes - 2700 miles. 3000 mile service coming up.
Yes free play - pull down point to push-up point 35mm which is ok
according to the manual.
Not talking bone-jarring/unrideable just not quite as smooth a ride as before the adjustment.
Wheel alignment and slight overtightening do seem the most likely explanations.
Daddystu
Pete.
PostPosted: 06:38 - 05 Jun 2023    Post subject: Reply with quote
Slacken off axle, loosen adjusters 1/4 turn, bash tyre forwards, re-tighten axle and ride it. If it is not the same then you had it too tight, or your carrier bearing is shot.
a.k.a 'Geri'
PostPosted: 00:06 - 08 Jun 2023    Post subject: Reply with quote
The rear sprocket may be out-of-round. Common thing.
You therefore need to adjust the slack in the chain to be at the the tightest position when the wheel is rotated.
If its substantial, you can watch the slack on the lower part of the chain change as the wheel rotates.
TLDR
The adjustment was checked at the slack part of rotation.
So the chain will go banjo when the slack is taken up byt the sprocket.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.6 - MySQL Queries: 17 - Page Size: 72.08 Kb
