| Author |
| Microwaveable |
 Microwaveable L Plate Warrior
 Posted: 10:43 - 03 Sep 2023 Post subject: 1998 cb600f3 clutch |
Hi all. We are trying to find all the parts for a clutch rebuild. I see from our local Honda shop, some parts are not available even from Japan. Any idea where we might find these. Thanks in advance. Please see below
Details below, prices retail inc gst (x Japan is approx. 3 weeks)
#6 22125-ML7-000 (Seat, Judder spring, x1) $24.59 x japan
#7 22201-MAL-600 (Disk, clutch friction , x8) $38.96 ea x auck
#8 22202-MAE-000 (Disk B, clutch friction, x1) $38.96 x auck
#9 22321-ML7-000 (Plate clutch, x8) $23.38ea 3x auck 5 x japan
#11 22361-MAL-600 (Plate clutch lifter, x1) No longer available
#13 22401-MV9-670 (Spring, clutch, x4) $16.58 ea x japan
#14 22402-ML7-000 (Spring, judder, x1) $50.85 x japan
#17 90241-KM9-000 (Nut, lock, 20mm, x1) $27.70 x japan
#18 90432-121-000 (Washer, lock, x1) $14.83 x japan
#19 90457-MV9-670 (Washer, 22mm, x1) no longer available
#20 90554-700-000 (Washer, trust, 20mm, x1) $9.68 x japan
#21 91001-KA4-003 (Bearing, radial ball, 12x, x1) $35.45 x auck
#22 91026-MV9-671 (Bearing, needle, 35x42x23, x1) $108.16 x Japan |
| Back to top |
| stinkwheel |
| Back to top |
| Kawasaki Jimbo |
 Posted: 17:08 - 03 Sep 2023 Post subject: |
| Back to top |
There is a gap of 194 days between these two posts... |
| Microwaveable |
| Back to top |
| stinkwheel |
 Posted: 08:24 - 16 Mar 2024 Post subject: |
I'd imagine it will be somewhat grabby with no oil in. May also need some adjusting.
You should be able to see the clutch stack seperating when you pull the lever if you look in through the oil filler hole with a torch. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| Microwaveable |
| Back to top |
| Fullers1845 |
 Fullers1845 Nova Slayer
| Back to top |
The last post was made 1 year, 335 days ago. Instead of replying here, would creating a new thread be more useful? |
