zoombini |
 zoombini Two Stroke Sniffer
Nobby the Bastard |
zoombini |
 Posted: 17:32 - 06 Sep 2023 Post subject: |
I'd start by checking for blown or loose fuses in the main fuse box. It's possible they created a short circuit when they moved the flashers or trapped a wire under something.
Also have a good look at the main 30A fuse and it's holder which are prone to corrosion on those bikes. The main fuse is on the side of the starter solenoid which you can find by following the big fat wire from the battery positive, the solenoid is on the other end of it. If the holder is all full of crumbly green corrosion, you may well have found your problem.. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
zoombini |
megaross |
 megaross Borekit Bruiser
The last post was made 1 year, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
