Honda VT500E Trip miles reset knob - which way?
tranx
PostPosted: 08:12 - 29 Nov 2023    Post subject: Honda VT500E Trip miles reset knob - which way? Reply with quote
New to me is a VT500EF which has a (rotary?) knob on the dashboard for resetting the trip-miles.
The previous owner said it was stiff but did work, but the knob is worn and very stiff so I don't want to force it in the wrong direction.
So my question is: in which direction does it operate to reset the trip meter, clockwise or anticlockwise, please?
PostPosted: 09:10 - 29 Nov 2023    Post subject: Reply with quote
my guess - clockwise (if ithe knobs on the LHS)
The numbers usually realign in the 'normal' working mode of rotation
tranx
PostPosted: 11:04 - 29 Nov 2023    Post subject: Reply with quote
That was most useful, thank you.
There is a degree of axial play, which seems to alter the feel of things when the button is either pushed or pulled while twisting it. You did not refer to this but could you confirm that it is unlikely to be relevant?
I have in mind that once, on a cbr400rr, it was surprising that the stop light switch could so easily be disassembled for cleaning, and especially that I could get it back together, and working.
The reset still won't budge, and I guess this is more tricky than a stop switch. Lack of expertise makes me worried about too much fiddling so, before I have a go, could you say something about how these workings are arranged and how accessible and repairable they might be?
PostPosted: 12:11 - 29 Nov 2023    Post subject: Reply with quote
Some silicone spray and a 24h wait might be a better idea?
jeffyjeff
PostPosted: 20:15 - 30 Nov 2023    Post subject: Reply with quote
Turn it forward. Cool
tranx
PostPosted: 08:28 - 01 Dec 2023    Post subject: Reply with quote
Thanks for the confirmation - after trying penetrating lubricant, it still will not budge
PostPosted: 08:50 - 01 Dec 2023    Post subject: Reply with quote
Anticlockwise using molegrips.
PostPosted: 09:44 - 01 Dec 2023    Post subject: Reply with quote
Errm yeah, possibly that way too.. Embarassed
BTW does it have to be depressed or pulled out then turned like a watch?
tranx
PostPosted: 15:43 - 18 Dec 2023    Post subject: Reply with quote
That seems to be right because I got a spare speedo which has the reset knob sprung anticlockwise i.e. backwards. That's unlike the one installed which has no bias and is just sloppy, so swapping speedos seems like the way to go.
Next is to replace the coolant and on some VT500 diagrams there appears to be a cap on the overflow tank, which is beneath the air filter/filter box, but can't find one on mine ('1987 EF'). Is there one?
or maybe when the cold rad has been filled, and topped up when all the air has come out, it will displace the right amount automatically into the overflow when it heats up?
So far have changed the oil & filter/transmission oil, lubricated cables, and it starts easily and runs smoothly. Gearbox and clutch are smooth and easy, with no noticeable play in the driveline. Suspension, seat, and riding position are very comfy except that foot pegs seem unnecessarily high.
Torque is good from 3000rpm and it seems to like revving, with redline at 9500. Haven't risked motorway yet but guess it will be happy at 70 in the high 6th gear. It's already perfect for shopping but can't find any panniers for it, or saddle bags to go under the seat...
tranx
PostPosted: 12:59 - 01 Jan 2024    Post subject: Reply with quote
I took a spare panel apart to see how the speedo works. The tiny screw which holds the knob to the shaft was easy to remove after all, being finger tight. Then the whole speedo could easily be removed from the inner panel with just two screws.
To reset the trip miles:-
1. turn the trip knob clockwise, against the light return spring.
2. while holding it rotated, push the knob in, which sets the trip to zero.
By default the knob is held 'out' by a light spring and a rubber sleeve on its shaft, when it cannot be pushed in because of a stop plate.
Rotating the knob clockwise allows a tag on its shaft to pass the stop, so it can be pushed 'in' to move a row of connecting gears away from the mile-counting rollers, each of which is sprung to return to zero.
On the bike this action was not obvious because the shaft to which the knob is attached was a bit gummed up.
tranx
PostPosted: 13:22 - 25 May 2024    Post subject: VT500 EF 1987 Reply with quote
tranx wrote:
...Next is to replace the coolant and on some VT500 diagrams there appears to be a cap on the overflow tank, which is beneath the air filter/filter box, but can't find one on mine ('1987 EF')....
- It's under the seat
tranx wrote:
...Torque is good from 3000rpm and it seems to like revving, with redline at 9500. Haven't risked motorway yet but guess it will be happy at 70 in the high 6th gear...
- 70 comes up easily at 5500 in 6th but there is more 'go' available in 5th, so 6th is an overdrive.
The throttle is high geared too, with less than a quarter turn to full throttle. This makes it feel responsive, like a 'sport mode' but without fuel injection's tendency to jerkiness.
Handling is very light but steady, with excellent balance of springs and shocks for the bumpy lanes, except that at low speed it can occasionally feel a bit unsure in a straight line, which might be due to road surface, Bridgestone Battleaxe BT46/tyres, or pressures?
There is an easy centre stand, low seat height and very comfy, and the small screen is not just cosmetic because at 5' 10" it definitely reduces wind blast and buffetting. Great for cruising and longer journeys.
The mirrors and dashboard/clocks are super-visible and in just the right places, with the prominent turn indicators being excellent reminders.
Engine and gearbox are very smooth, the bike feels light but solid and it's all amazingly sophisticated for 1987.
Downsides? Road dirt sandblasts the swing arm bridge; knees feel a bit high at first; sidestand is a bit flimsy; back end seems unnecessarily high.
The last post was made 1 year, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 70.88 Kb
