22 WR450F just picked up - milky oil, leaking blue liquid
fasterski
PostPosted: 23:32 - 04 Feb 2024    Post subject: 22 WR450F just picked up - milky oil, leaking blue liquid Reply with quote
Hey everyone,
Just picked up a brand new (it was still in the crate last Wednesday I'm told ) . Old stock i guess.
Got it home earlier in a week. Started this weekend, wanted to take it for a quick spin as it is still winter in Toronto. Sunny day around 32 F.
Bike is warming up. Header glowing orange which is normal for this bike i 'm told . I can see and smell the factory oils from the exhaust / headers burning off. Ready to go with all the gear up as I'm about to hop on it I see a blue coolant pooled on the floor under the bike. I see blue liquid dripping of the rock guard under the bike. WTF? I shut the bike off, level it up trying to see where it is leaking from. Then I look at the oil window. It is milky , light brown.
Has anyone heard of this happening on a new bike ???
I'm calling the dealer tomorrow. Bike is already on the trailer ready to be sent out.
Just wondering if with issue like this should I be asking for another bike ??
Robby
Dirty Old Man
PostPosted: 00:10 - 05 Feb 2024    Post subject: Reply with quote
Certainly one to go back to the dealer.
Best case, the emulsion in the oil is from condensation and the coolant leak is from the expansion bottle being overfilled. However both together and I expect the water pump gasket has failed, and it's leaking coolant out of the bike and into the sump.
First start is about the worst possible time to have water in the oil too.
doggone
PostPosted: 16:22 - 05 Feb 2024    Post subject: Reply with quote
I wouldn't be that surprised if some coolant leaked out as it got to temperature and expanded a bit.
I'm not sure you could get emulsified oil on first run either even if there was (say) head gasket leak.
If it was mine I'd not panic and see what happened on subsequent start ups most likely but might run symptoms by dealer.
Leaving it stationary to get to temp is not 'normal' use and not good for any bike IMO.
fasterski
PostPosted: 19:32 - 08 Feb 2024    Post subject: Reply with quote
Looks like the diagnostic from the dealer was that
A) oil was not clean due to engine running , once it settles it goes back to amber
b) the oil in the engine was 2 years / old / special break in oil so it was a bit hazy (not perfectly clear )
c| coolant on the floor was due to engine idling for too long getting hot. Overflowing from the reservoir.
All in all they changed the oil. I ran it and observed the oil getting cloudy after shutting it off. Then in about 1 hour it settles and looks clean after the change.
They filed the service report with the comments with Yamaha in case something happens.
Never had this happen with my other bikes, but I have never owned MX type bike so it was a bit novelty to me.
Just posting in case someone comes across it or calls BS... Smile
PostPosted: 19:45 - 08 Feb 2024    Post subject: Reply with quote
If thet was mine I wouldn't be happy. The bit highlighted in bold suggests to me there is some other fluid in the oil and it's settling out.
If it was me I'd probably drain the oil out into some clear container and see if there is any separation of fluids after a time.
It might well be fine but I can't see a reason new oil would go cloudy then clear and as an engineer that doesn't sit well with me.
Triumph Trophy Launch Edition
fasterski
PostPosted: 01:38 - 09 Feb 2024    Post subject: Reply with quote
They did drain the oil. Checked it for any water. They did say they know how oil looks mixed with water from all the ATV folks coming in for service.
After the change the oil looks perfect before start and 1 hour after engine is shut off. (that's how long it took me to drive it home. ) Have not tried it since. Waiting for the weather to warm up.
Trust me it is not sitting well with me as well.
A100man
PostPosted: 13:59 - 09 Feb 2024    Post subject: Reply with quote
Are you sure the oil isn't just a bit 'frothy' with after running -that would chang the appearsnce and then settle out. As suggested draining the oil into transpaernet vessel to observe any separation will be best bet.
The last post was made 2 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.47 - MySQL Queries: 14 - Page Size: 57.57 Kb
