Terminal Box / 4 Connector after a relay
kawakid
PostPosted: 16:37 - 28 Dec 2023    Post subject: Terminal Box / 4 Connector after a relay Reply with quote
Hello,
Number 2 son, currently has a newish CB500F.
We (I) are about to fit a relay, for heated grips & phone charger.
I know how to fit a relay (I even wrote a massive post on this ~ 17 years ago on this forum).
However I am one of these people who in the past did do a lot of bike and car maintenance , but then got older, richer and time poor and then paid people to do things I once would happily do.............
Number 2 son, wants dad to do it.
Fast forward 17 years
From terminal 87 from the relay, years ago (if i've needed 2 connections), i've just used a piggy back terminal or just soldered wires together.
But thinking about it. On Amazon, there are things like this:
https://www.amazon.co.uk/Motorcycle-Install-Universal-Electric-Vehicle/dp/B0CFYNCS9S
Or (i've loads of these already), but do people use them on the bike? )Do they handle vibration etc?)
https://www.amazon.co.uk/flintronic-Lever-Nut-Connector-Conductor-Connectors/dp/B09XJZ8TRB
Not sure what's the best method, just thinking if idiot son decides to add something else.
Hope this makes sense
I've a twin and a 4.
PostPosted: 19:12 - 28 Dec 2023    Post subject: Reply with quote
I use these things which hold the relay and three blade fuses.
https://www.ebay.co.uk/itm/141098710151
https://lh3.googleusercontent.com/pw/ABLVV87cUFUuM7_lqbby2F0H3XXZgYu_pcPClRj76ADPrffhefPhB2HEc6DcnnISxjSVCHpr-8YfiuupOIrLrMwY1ueT5UuHzdV0pU48Y_l1y5_cnmzVede80quiwRTx9E_haCFZDqqXw-yw8b6uCqqcAeV0=w1547-h870-s-no
kawakid
PostPosted: 23:45 - 29 Dec 2023    Post subject: Reply with quote
That is quite neat.
I like my fuses.
In the past I fused from the battery to the relay then individually to each device.
Do people fuse to 30? Or is it overkill?
PostPosted: 00:54 - 30 Dec 2023    Post subject: Reply with quote
kawakid wrote:
That is quite neat.
I like my fuses.
Work out what your maximum expected draw is then go the next fuse up or the maximum current your cable will take and use the next fuse down.
I haven't fused the relay, maybe I should have (you also get relays with intergral blade fuses) but I'm not going to, all it would be protecting is the relay itself and the short piece of wire between the battery and the relay.
kawakid
PostPosted: 19:06 - 30 Dec 2023    Post subject: Reply with quote
Thanks I won't bother either.
jeffyjeff
PostPosted: 21:13 - 02 Jan 2024    Post subject: Reply with quote
FWIW, it's best to use a suppressed relay: one with an internal resistor or diode in parallel across the coil. Relay coils are similar to ignition coils, and generate high voltage spikes when turned off. Voltage spikes can wreck havoc on sensitive solid state circuits, and cause electrical problems that are difficult to trace.
The last post was made 2 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.63 - MySQL Queries: 14 - Page Size: 49.83 Kb
