TDM 850 1998 Starting fault
Wilskie
PostPosted: 23:42 - 16 Mar 2021    Post subject: TDM 850 1998 Starting fault Reply with quote
Hi all , I have a strange fault with my TDM850, to start with it has been sitting for a while. I have replaced the battery and now it cranks over just fine but only on the first press of the button it sparks but after that no spark from the plugs. Any help would be much appreciated.[/list]
R.Wilson
jaffa90
PostPosted: 00:49 - 17 Mar 2021    Post subject: Reply with quote
Does your (old) Laughing bike have any safety cut out switches that kill the spark only? Somebody on here may have the same bike.
Wilskie
PostPosted: 10:06 - 17 Mar 2021    Post subject: Reply with quote
Hi thanks for your reply , I honestly don't know . It does seem very strange as both plugs act the same way with only the initial spark then nothing.
R.Wilson
Easy-X
PostPosted: 12:49 - 17 Mar 2021    Post subject: Reply with quote
Both sparks you say? I was about to use the phrase "wasted spark" but if this is the correct manual:
https://www.manualslib.com/manual/816356/Yamaha-Tdm850-99-4tx-Ae3.html
...then it has coil-per-sparkplug. It looks like the sort of "pre-ecu" affair I'd expect, the Relay Unit being the typical convoluted jumble to enable the safety features Rolling Eyes
Try turning it over with the clutch pulled in, see if it makes any odds Thinking
Wilskie
PostPosted: 21:18 - 18 Mar 2021    Post subject: Reply with quote
Hi again I think I will try another ecu on my bike to try and resolve this starting issue , are they compatible with each other or are they set for each individual bikes. Thanks
R.Wilson
Nobby the Bastard
Harley Gaydar
PostPosted: 22:07 - 18 Mar 2021    Post subject: Reply with quote
The only time ecus are specific to a car or bike is if there's an immobiliser as well and only if the ecu and immobiliser are set together in the factory.
The only time I've come across the two being linked like that was on a fiat bravo so i really don't think it will be an issue. Assuming the connections are the same swapping e us should be fine.
I'd still be looking at clutch and sidestand switches.
The way to tell if its wasted spark is to follow the ht leads. If they do to a single coil its wasted spark and you would expect both to spark at the same time.
Generally a twin would be a wasted spark in the same way that a 4 is two wasted sparks.
V2 and v4 are different, obviously, as are twins that are emulating a v.
Triumph Sprint ST 1050
Easy-X
PostPosted: 01:05 - 19 Mar 2021    Post subject: Reply with quote
Trying out another ECU would only help if the bike has an ECU to start with Wink AFAIK Yamaha didn't go fuel injection on this line till the TDM900.
Nobby the Bastard
Harley Gaydar
PostPosted: 11:26 - 19 Mar 2021    Post subject: Reply with quote
It will still have some sort of electronic ignitor box for the sparks.
Easy-X
PostPosted: 13:04 - 19 Mar 2021    Post subject: Reply with quote
Indeed but it looks like the one on the TDM850 is rather straightforward. The only inputs are the magneto pickup, TPS, safety features (gear position, side stand, etc.) and fuse box. Outputs are the two coils.
Best to check the exterior components first I would say Thinking
There is a gap of 2 years, 309 days between these two posts...
Ingo
PostPosted: 05:09 - 23 Jan 2024    Post subject: Reply with quote
Hi all
I’m using a phone so it’s hard to navigate.
I have the exact same problem re the single spark on just the left cylinder and no spark after that.
Was a solution ever found for this problem?
I am also not a everyday forum user.
Help would be much appreciated.
I have done all the checks
New plugs
New ht leads
Second hand cdi/ecu
I’m thinking it’s the pickup from the generator.
Thanks ingo
Ingo
PostPosted: 09:28 - 23 Jan 2024    Post subject: Reply with quote
Try swapping the coils over and see if the problem changes sides. Also if it's a similar problem where the bike has been sat fro some time, go through all the relevant connectors and give them a clean.
WD Forte
PostPosted: 12:46 - 25 Jan 2024    Post subject: Reply with quote
so what is it?
CDI or ECU ?
pretty major difference y'know
bikers smell of wee
The last post was made 2 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 14 - Page Size: 71.3 Kb
