bike not shifting past gear 2
ben_b2003
PostPosted: 08:00 - 12 Feb 2024    Post subject: bike not shifting past gear 2 Reply with quote
Hi all, hope you’re all having a good day so far. Im posting this because I’m currrbtly having problems with my Benelli BN 125 and I can’t figure out what’s wrong with it. Anyways I seem to have a problem changing gear, my bike won’t shift past gear 2 and I’ve noticed the lever when in gear is in a weird position, in gear 1 it’s to low and when you shift up to gear 2 the lever goes really high just like how it would be if you were in top gear. Also I’ve noticed some play in the part what goes inside my engine attached to my shifter which I’ll attach a video of.
(GUYS I KNOW THE BOLT ISNT ATTACHED I TOOK IT OFF WHEN TRYING TO FIX IT) the problem persists even when the shifter is attached
doggone
PostPosted: 09:33 - 12 Feb 2024    Post subject: Reply with quote
Something has come adrift probably due to wear inside by the look of it.
No easy answer it will need opening up.
Even if there was some trick to get selectors back in correct position it will likely keep doing it.
PostPosted: 09:52 - 12 Feb 2024    Post subject: Reply with quote
Your fucking gear lever isn't connected to the fucking frame of the bike. it's only conected to the selector bar/mechanism.
Thats got to be the most obvious fault in the fucking world and I'm fucking pissing myself.
Triumph Sprint ST 1050
PostPosted: 10:01 - 12 Feb 2024    Post subject: Reply with quote
The two arrowed bits should be bolted together.
https://www.bikechatforums.com/files/untitled_134.jpg
doggone
PostPosted: 10:23 - 12 Feb 2024    Post subject: Reply with quote
Oh yeah - bolt has come out I hadn't downloaded the exciting video Laughing
that_impulse_guy
PostPosted: 10:26 - 12 Feb 2024    Post subject: Reply with quote
these two bits should be joined together
ben_b2003
PostPosted: 12:15 - 12 Feb 2024    Post subject: Reply with quote
yes i know i took the bolt out when trying to find a fix the problem stated in the post persists even when the lever is attached
ben_b2003
PostPosted: 12:18 - 12 Feb 2024    Post subject: Reply with quote
awh that doesn’t sound good so you recon it’s something serious and will require alot of money at mechanic.
Freddyfruitba...
PostPosted: 12:29 - 12 Feb 2024    Post subject: Reply with quote
Your fucking gear lever isn't connected to the fucking frame of the bike. it's only conected to the fucking selector bar/mechanism.
FTFY
DaddyStu
PostPosted: 12:31 - 12 Feb 2024    Post subject: Reply with quote
Cant make it out clearly but its not just sliding around on those worn engagement pawls is it? Or tightened up in the incorrect position?
Other simple initial checks for me would be clutch cable slack, chain slack and oil level.
Daddystu
ben_b2003
PostPosted: 12:34 - 12 Feb 2024    Post subject: Reply with quote
ye i ain’t that stupid mate. the purpose of the video was to show the play on the part what attaches the shifter to the engine. probably my fault for uploading a vid when the shifter wasn’t attached which had caused confusion.
ben_b2003
PostPosted: 12:40 - 12 Feb 2024    Post subject: Reply with quote
don’t think so mate cant be tightened up wrong because I remember trying to go for a ride and the problem started out of nowhere as soon as i tried to ride off. and chain slack and oil level is ok.
PostPosted: 14:53 - 12 Feb 2024    Post subject: Reply with quote
All the stuff that does the actual changing of the gear including the spring that pushes the actuator shaft back to level position isn't really affected by that very minor movement in and out.
slowasyoulike
PostPosted: 16:09 - 12 Feb 2024    Post subject: Reply with quote
That amount of in/out play on the gear lever shaft doesn't look like anything to worry about, C90s seem to have that much by default and I've seen plenty other gearboxes like that which functioned normally.
IME the obvious thing when people can't change gear is that they've got the drive train dragging in the road, but I see you've checked that. Plus that wouldn't account for the excess movement in the lever... have you checked the state of the splines on the lever and the shaft?
that_impulse_guy
PostPosted: 11:46 - 13 Feb 2024    Post subject: Reply with quote
it also easy sometime to have the lever fitted one spline too high, which tends to translate as can select first, neutral and second but no more.
it may have jumped a spline when changing up....pls check mechanical interferences first (gear lever hits on engine case when changing up)..the play you showed is nothing to worry about.
PostPosted: 12:44 - 13 Feb 2024    Post subject: Reply with quote
Take the whole linkage off the splines. Stick the bike on the center stand or axel stand. Put mole grips on the splines for the gear change. Start it up and run it through the gears. If it works it's something to do with the linkage. If it doesn't it something to do with the selectors.
Triumph Trophy Launch Edition
PostPosted: 12:53 - 13 Feb 2024    Post subject: Reply with quote
Thats a really good way of fucking up the splines.
Just unbolt the mechanism from the bottom of the shifter if you think that is at fault.
PostPosted: 14:57 - 13 Feb 2024    Post subject: Reply with quote
All I see in that vid is a bit of end float and nothing to cause concern
OK you got the lever pivot bolt removed that's ok leave it like that for now
I'd put in on the mainstand get it to neutral then rock the rear wheel
and work the linkage to see what gears I can get
(Mole grip on the first wee lever not the splines may help but you should only need moderat force)
normally I'll be able to go up and down all 5 gears but if you still cant get past 2 then issa fooked so burn it send it to thell
PostPosted: 16:04 - 13 Feb 2024    Post subject: Reply with quote
Only if you are an incompetant neanderthal.
sickpup
Old Timer
PostPosted: 21:57 - 13 Feb 2024    Post subject: Reply with quote
Likely a broken spring on the end of the shaft.
PostPosted: 16:35 - 14 Feb 2024    Post subject: Reply with quote
Is the clutch releasing properly?
If there's still drive going through the clutch then gear changes will be sticky.
(It should be possible to change gear by driving through the changes without clutch. Back wheel off the ground.)
The last post was made 2 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.85 - MySQL Queries: 13 - Page Size: 107.59 Kb
