| Author |
| stinkwheel |
 Posted: 16:50 - 14 Feb 2024 Post subject: Hub dimensions? |
I'm looking to get new rims for my Minsk 125 and I'd rather not have to go down the road of getting a set drilled. I find motorcycle wheelbuilding companies both very slow and little short of a pain in the arse to deal with. Plus as soon as you want something custom making, the price skyrockets and this is a cheap, basic bike.
So I'm looking for something reasonably common with a close enough rim diameter and width that I can buy a set of off the shelf or used rims and lace them up to my hubs. The angles of the holes in the rim need to be right for the spoke angles on motorcycle rims.
They are dead simple. Even diameters on both sides of both hubs, 36 holes, 18" rims. They look very similar to drum-brake Honda hubs. CG125, CB250 etc.
I just can't find anywhere that has a list of spoke hole diameters and widths for motorcycles (it's readily available when you build bicycle wheels).
Mine are near as damnit 180mm diameter and 52mm wide. So something in that ballpark. I wonder if anyone has a bike with similar hubs that would mind measuring them for me? It's the diameter of the ring of spoke holes, not the overall diameter and the width at the spoke holes that's the important measurement. The holes would all need to be in a circle, not offset.
https://lh3.googleusercontent.com/pw/ABLVV85UJjeX3jknqscsaPr3g6woRSlAuj8Oh_yPgp5XF-FHtSDmC5iv8-QwyV2buwOCzhJRxg7E42YlTirMmbFK9JNrinZKneD9R4VdVCFBMcuAOx-fTcvydc17Tyz-YXQJ84xjTFaCI992ijfGeg8L4Jqt=w1547-h870-s-no ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| Easy-X |
 Easy-X Super Spammer
 Posted: 17:59 - 14 Feb 2024 Post subject: |
Any help?
https://www.devonrimcompany.com/ ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| stinkwheel |
 Posted: 18:52 - 14 Feb 2024 Post subject: |
Not really. I'd have to tell them all about my hub and wheel dimensions so they can custom drill the rims. They are a wheelbuilders and so will immediately become an overpriced pain in the arse as soon as you aren't buying something off the shelf.
I've been there before and can't be bothered with the fuck-on, I'd rather paint the ones I have than have any actual direct dealings with one. In much the same way as I can no longer be arsed going into a motorbike shop and spending 20 minutes arguing about wether or not I want a part it turns out they'd have to order in anyway. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| WD Forte |
 WD Forte World Chat Champion
| Back to top |
| stinkwheel |
| Back to top |
| WD Forte |
| Back to top |
| A100man |
 A100man World Chat Champion
| Back to top |
| stinkwheel |
 Posted: 22:29 - 14 Feb 2024 Post subject: |
Possibly, but again, no idea what size the hubs are. I know the 350 ones are way too big. Maybe one of the 125 or 50cc ones but it would be like buying a random rim for anything else.
It's surprisingly important, if you get the holes drilled at the wrong angle, it puts a warp in the spokes and they can and do snap. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| A100man |
 Posted: 11:24 - 15 Feb 2024 Post subject: |
| stinkwheel wrote: |
It's surprisingly important, if you get the holes drilled at the wrong angle, it puts a warp in the spokes and they can and do snap. |
Well, yes. As I discovered when, without thinking, I bought a random rim off ebay to build a rear wheel for my GT250 which has a mahoosive hub - (the same as teh 550 I think) as a result the required spoke angle is quite acute and I drilled out and counter sunk the holes to get the nipples to sit even half flush..
In the end I chanced it and it appears to be OK, although not greatly tested with my 67kg bulk. TBH I'd have thought if the hub is approximately the same it would be 'good enough'. Jawa link sent cos
Iimagined all Iron curtain stuff to be approx the same.. maybe.. ____________________ Now: A100, GT250A, XJ598, FZ750
| Back to top |
The last post was made 2 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
