Seat rebuilding - DIY tips?
PostPosted: 15:51 - 17 Mar 2024    Post subject: Seat rebuilding - DIY tips? Reply with quote
I'm thinking of making a slightly more comfortable seat for the Husky and wondering if anyone has any tips. I'll probably start with a second-hand Svartpilen seat:
https://i.ebayimg.com/images/g/p98AAOSwnxxljFRc/s-l640.jpg
As that cuts the work in half, literally Smile Might keep the original cover, might buy something jazzy, not really important.
Here's a back profile:
https://i.ebayimg.com/images/g/tIsAAOSwKBBljFRb/s-l640.jpg
Any tips for materials, layers, tools, etc. ? Something like a firm foam base and a gel layer on top?
PostPosted: 16:01 - 17 Mar 2024    Post subject: Reply with quote
Heat gun is your friend for covering it. And a staple gun. And a staple remover so you can use tacking staples to hold it roughly where it wants to be and pull it down the rest of the way once it's more in order then take them out.
People generally use the high density upholstery foam made from chopped bits of other foam. An old fashioned electric carving knife is the ideal tool for shaping it, but they are getting hard to find these days.
PostPosted: 16:07 - 17 Mar 2024    Post subject: Reply with quote
Heat gun - check, staple guns - check. This is why I thought I might give it a go Smile
PostPosted: 18:00 - 17 Mar 2024    Post subject: Reply with quote
Shouldn't be hard to cover, it's mostly flat. I'd even expect to get the back all in one piece. I'd probably start there and work forwards.
PostPosted: 19:16 - 17 Mar 2024    Post subject: Reply with quote
It's OK to put foam and a cover on a seat.
The skill is to put the foam where is works best.
And some foam will compress to a solid so cushioning is lost.
What is on the original?
I'm sure there is a compression index for foam.
It's not rocket surgery.
PostPosted: 21:18 - 17 Mar 2024    Post subject: Reply with quote
I've put on offer on a decent looking eBay seat, most likely they'll accept come the morrow. We'll see what it's made of.
The back end in the photo looks fat but I doubt the bit you actually sit on comprises even half an inch of foam. Dirt bikes seats are more luxurious. In contrast, the old fella's bought a new seat for his Breakout:
https://saddlemen.com/image/cache/catalog/data/product/813-27-029LS-1000x1000.jpg
Two-wheeled armchair.
jeffyjeff
PostPosted: 03:00 - 18 Mar 2024    Post subject: Reply with quote
I'd like to see how this comes together. May I suggest this might be a good topic for a "show and tell" post.
PostPosted: 11:42 - 18 Mar 2024    Post subject: Reply with quote
The offers have been accepted on the eBay parts. My Vitpilen seat is a single "long bench" whereas the Svartpilen is in two bits. I'm 99% sure the two systems are interchangeable Shifty Anyhoo, premium effort on the front riders half but no need to reupholster the rear pillion part Smile
Be interesting to see what the faux-leather/vinyl is like unpicked and laid flat - see how the ppl punting custom covers justify >£200.
PostPosted: 14:46 - 19 Mar 2024    Post subject: Reply with quote
1) I recovered my XJ550 seat a year or so back. The top inch or so of foam was old and 'crusty' so I cut it out and replaced with memory foam. seems better but not ridden it for a long journey yet.
2) I also recovered theFZ seat but I used glue (like CT1) rather than staples cos I didn't have staple gun at that point. This also worked OK but I used lots of clamps and spring clips to keep the cover taut while the glue set- I also did it in stages starting at the front.
3) You can buy 'two way stretch' vinyl which stretches in err, two planes. this will make your life easier.
PostPosted: 16:28 - 19 Mar 2024    Post subject: Reply with quote
FYI there's a factory option for an "ergo seat" something like €180 but no one seems to rate it as any more comfortable, just looks jazzy. I mention it as for covers the only off-the-peg option seems to be hand-made Italian leather at > €200 Shocked Given I can't see any cheaper offerings I'm assuming everyone's making their own seat covers! The second-hand seat combo turns up tomorrow so in the meantime I'm enjoying a nice cup of tea and researching how people make custom seat. Fuck me, what a rabbit hole Sad
Gel inserts seem to attract mixed opinions: plebs rave about 'em and custom seat makers suggest you wouldn't need such things if the work was done correctly in the first place. Oh, and apparently you want orthopaedic gel not the cheap eBay stuff Thinking
As for the foam base, I thought I'd look at how my Noble gaming chair is built and they boast they use 60kg/m3 high density foam (~3.7lb/ft3) but that doesn't take into account the firmness Rolling Eyes Standard heavy duty upholstery foam is ~3.5lb/ft3 in comparison.
But wait! Seat covers are billed as "mostly water resistant" so maybe what you actually want is waterproof "Closed Cell Polyethylene Foam." Translation: yoga mat Wink And of course the density/firmness is completely different to upholstery foam.
Maybe top it all off with a memory foam layer and it's starting to look like one of those epic sandwiches Shaggy makes in Scooby Doo Very Happy
Ayrton
PostPosted: 11:42 - 20 Mar 2024    Post subject: Reply with quote
I was going to do my SV seat and found this site pretty helpful. It's not on the internet anymore though so you've got to use the archive to view it.
https://web.archive.org/web/20190228143932/https://diymotorcycleseat.com/foam-types/
Never did get around to doing the seat. I bought some yoga mat to use as a base and then a thin Polyurethane foam to go over the top just to smooth things out. I don't really want a super soft seat I just wanted it a little wider to spread the weight more
PostPosted: 11:59 - 20 Mar 2024    Post subject: Reply with quote
Excellent find! Bookmarked Thumbs Up
PostPosted: 12:25 - 20 Mar 2024    Post subject: Reply with quote
For what it's worth, I used this stuff to cover my seat and it was fine. It's extremely tough and moderately stretchy. I don't think you have many complex curves on yours that would demand it being stretchier.
I could have gone a grade thinner for mine because I struggled then gave up getting it to stretch over the front. I feel if I'd had slightly stretchier vinyl or the ability to tack it with staples to the base and work it into position, I'd have got it all in one piece. The rivett on metal base worked against me.
https://www.ebay.co.uk/itm/333800895790
https://lh3.googleusercontent.com/pw/ADCreHe2h73pa2Ip0Qgoh8cWakWct7AYNTNxOMaGYBbcPGP21x33jX87auAj8EgGtMGxIr76ISt70GCKS-XHEmOaE8hsGMJD9KsHx_wmcv9zPLK3V7vD8_ot6p7AHx_CTRSneghrBmGCFiGvScFooUtGet3g=w1547-h870-s-no
https://lh3.googleusercontent.com/pw/ADCreHebN09CNeC5x9GEw5aXmD58pp-pfOsIVjST6AyzqdhEqO127CJRjj_CRHPvOG0lBwge8Te3LmAJSJKvBB1LcZxh_5sigcKmTIOHCynmoKj-PrDZin2P_oc0OLNAQgrgp8l1msn4YZTpVoC8AMnod1j_=w1547-h870-s-no
UncleFester
PostPosted: 12:50 - 20 Mar 2024    Post subject: Reply with quote
Air powered / electric staple gun if you can find one and pay attention to the length of the staples and also the type. A good small hammer can be useful to flatten any proud ones. Also keep an eye on the underside for any place the base of the staples might come into contact with bodywork.
Other than that - prepare to sweat, it's pleasantly hard work.
2017 Z1000SX
PostPosted: 13:44 - 20 Mar 2024    Post subject: Reply with quote
Second-hand seat (front and back parts) just turned up and I think I've got quite lucky. For what's supposedly a 2021 part the front bit barely shows any evidence of use, certainly I can reuse the cover if needed. (BTW I didn't buy the one pictured.)
TBH the only alternative I'd consider would be Alcantara EXO in either black or charcoal. Seems a bit OTT though, more of flex "oh yah, custom seat, donchaknow" and that wouldn't square with my low-key, humble and unpretentious persona Wink
that_impulse_guy
PostPosted: 14:18 - 20 Mar 2024    Post subject: Reply with quote
as much as some find him marmite, Delboys garage did a video today on refoaming a seat. Using camping roll-up mats/yoga mats. (closed cell foam)
and also fwiw, I recovered my seats in 4 way stretchy vinyl off ebay (about £15 worth) and a staple gun all by myself. Needed heat from a hairdryer to get it to stretch nicely around trickier curves but did it on the floor while watching tv and didnt take half an hour.
The last post was made 1 year, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 94.94 Kb
