Brake calliper noise reduction.
BCF Central Japan
PostPosted: 03:38 - 18 Mar 2024    Post subject: Brake calliper noise reduction. Reply with quote
Hello, all.
This is my first post in this forum.
It seems this is a UK site.
I am from the UK, but I live in Japan.
This isn't really a greeting message.
This is a heads-up, not a call for help, for others who maintain their own bike (or, as in the case of my commuter, a 2015 PCX scooter).
I have just stripped down the front calliper to inspect and replace some parts as routine work. I noticed that (what I believe to be) the noise reduction strip was sitting at the wrong angle (behind the pads, above the pad springs). This prevented me from pulling the bracket from the calliper without force. Thinking that the calliper bracket was one piece and that the strip/tab/clip could not be coaxed back into position, I coaxed it out of the way (... bent it with pliers) to get the bracket and calliper apart. Not sure whether I ought to ignore it as a mostly redundant part, I spoke with the dealer I got the parts from. In fact the bracket is not one piece on my bike, and I have removed the strip and will ride without it.
Long story short...
If you're pads have pad grease (usually copper grease), and your floating calliper sliding pins have grease (usually silicone grease), you don't need these things.
Not a very profound or grand first post in the forum, I know, but if you, too, are a DIY owner mechanic trying to save money and learn to do as much as possible yourself, this might help.
Happy trails.
Three cheers for Honda... and three boos for Yamaha.
jeffyjeff
PostPosted: 07:02 - 18 Mar 2024    Post subject: Reply with quote
Greetings and welcome to the forum from a former L Plate Warrior.
Now that you have determined the function and proper orientation of the spring, why don't you install a new one in its intended orientation and assemble the brake per the Honda manual?
Might save you from having to do the job twice.
PostPosted: 07:32 - 18 Mar 2024    Post subject: Reply with quote
All good fun until the rattling noise starts.
PostPosted: 07:53 - 18 Mar 2024    Post subject: Reply with quote
It might just be me but the brakes are the last place I'd start experimenting with the manufacturers design.
Triumph Sprint ST 1050
PostPosted: 09:54 - 18 Mar 2024    Post subject: Reply with quote
Get a drill bit the same size as the holes in the brake disc and drill out the old brake pad material.
That shyte can cause noise.
The holes will appear smaller until the crap is removed so you may need a couple of step-up drill diameters until you find the steel.
PostPosted: 11:23 - 18 Mar 2024    Post subject: Reply with quote
For a new member I applaud the fact you got past the "forum attachment system" intelligence test Smile
jeffyjeff
PostPosted: 12:57 - 18 Mar 2024    Post subject: Reply with quote
Or worse, like when your PCX brakes howl like a freight train coming to a stop.
hellkat
PostPosted: 00:06 - 20 Mar 2024    Post subject: Reply with quote
Damn I got all excited thinking it might be Hetzer in disguise
*sulks*
The last post was made 1 year, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 56.22 Kb
