| Author |
| Easy-X |
 Easy-X Super Spammer
 Posted: 20:22 - 20 Mar 2024 Post subject: Seat Rebuilding Project |
As requested I shall journal my quest to rebuild a motorcycle seat...
Like so many bikes these days, the seat on my Husky leaves something to be desired after an hour or so of riding. The current Vitpilen factory seat is somewhat like the classic "long bench" with a slight nod to dirt bikes:
https://hqvadventure.com/forum/data/attachments/0/795-538de028c84233bb667f036b30f907e1.jpg
The similar Svartpiken seat comes in two parts:
https://hqvadventure.com/forum/data/attachments/0/794-2a81b4462eab13492a141c644ef75eca.jpg
I've got hold of the latter second-hand as I can skip re-upholstering the back/pillion part
Comparison on the bike:
https://i.imgur.com/b9da4jU.jpeg
Both are covered by vinyl but the Vitpilen tries to fake a suede look:
https://i.imgur.com/XhS0YFH.jpeg
Let's take a look at how the seat is put together. Quick rifle through the tool drawer and one cup of tea later...
https://i.imgur.com/ZjaOBvr.jpeg
So classic vinyl cover over a single moulded piece of foam on a plastic tray base. Something worth noting if we look at the side views. Before:
https://i.imgur.com/hZnbtTx.jpeg
After:
https://i.imgur.com/WT7AOlT.jpeg
A bit of a kick-up to meet the pillion seat and a slight back-stop for your arse First glance of a fancy foam shape might be a little intimidating - how could such a thing be replicated?
This foam is just a single piece of material; there are no layers of density or firmness. It's quite a bit thicker than I imagined due to the "tray" nature of the base. Even so, grabbing a handful proves the foam to be about the consistency of marshmallow. Thick and soft is great in the showroom and sufficient for a test ride but for several hours riding one would need something much firmer. Definitely scope for improvement.
The Plan
Looking at the seat tray, it lends itself to a simple layered structure. I'm thinking...
1) Fill the recess of the tray with very firm (bordering on rubber) foam to create a flat base.
2) Firm foam centre for most of the shape.
3) Memory foam covering out to the edges.
4) Try stapling a sheet of faux-Alcantara as a cover (with the original cover as a backup option.)
5) Optional: convert the pillion seat into something else. "Café Racer Cowl" is the obvious. Somewhere to stash drugs some tools would be nice.
The layers will be glued together but I don't think there's any need to glue to the base itself. The bottom layer (if cut snuggly enough) should lock everything in place. The top and bottom layers will be simple sheets whereas the middle layer will be two or three chunks glued together to get the front and back kick-ups. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| stinkwheel |
| Back to top |
| Easy-X |
| Back to top |
| stinkwheel |
 Posted: 22:00 - 20 Mar 2024 Post subject: |
That evostick spray adhesive is useful for sticking layers of foam/stuff together. It doesn't need to be very well held, just enough to stop it slipping apart while you stretch the cover over it, then that holds it all in place. It's what I use to glue high density foam kneeling pads into my canoes. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| struan80 |
 struan80 World Chat Champion
| Back to top |
| Easy-X |
 Posted: 00:29 - 23 Mar 2024 Post subject: |
Materials have started appearing
I can't be arsed to break out specific weights for a deflection test but if we say the factory foam is at least 30mm thick you can easily pinch it down to less than 10mm. "Reflex" foam layer pinches down to nothing, as one would expect. Closed cell squished down 50% and the reformed foam by about a third.
I have enough material with the three replacement layers to replicate the thickest part of the old seat foam but probably, given the centre core will be ~3x firmer, I could make something a bit thinner overall. The Husky has quite a tall seat height for such a small bike but mostly that's affected by the "John Wayne" leg spread than the peak height of the seat foam.
Regardless, here's a rough cut:
https://i.imgur.com/ju6WKZE.jpeg
Need to look in the toolbox for a long, sharp knife to start carving some shape. It might be possible to use a sanding disk but I have a feeling reformed foam will tear up. I've saved the offcuts for testing. I could probably throw the seat straight on the bike now just for testing...
https://i.imgur.com/OVYNAwT.jpeg
...maybe later  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| UncleFester |
| Back to top |
| Easy-X |
 Posted: 12:33 - 23 Mar 2024 Post subject: |
That's interesting. I'd bought some "Scuba Suede" thinking that I'd use it for the actual cover but I think I'll stick with the original vinyl. I could combine it with my reflex foam to make the top layer, as you suggest.
As for shaping it's: sharp knife, old-skewl electric carving knife, hot wire and sanding. I'll try all the tools and see how they compare so just waiting on a hot wire kit from Amazon. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
 Posted: 15:11 - 24 Mar 2024 Post subject: |
Tool No.1 - Hot Wire
https://m.media-amazon.com/images/W/AVIF_800250-T2/images/I/71cYc3ixtVL._AC_SL640_.jpg
The above is a cheap kit from Amazon. I would suggest checking the specs for power output. Moar powa = easier to cut denser foam.
With care, the hot wire can make very straight precision cuts. Very little material is lost (the wire is ~0.2mm thick.) For the foam I'm using one would need to go at it very slowly but really the major limitation is the width of the wire. I can see if I want to cut out a curve I'd need to mark out the side profile and go a slice at a time, like cutting cheese
I'm now eyeballing the rear hump of the seat again. It'd probably be more efficient to start with a thinner piece of foam for most of the seat and the rear bit as a separate glued on piece
<edit> Nope. Looking at the original foam the thickest part is actually the midpoint of the seat where it kicks up/forward so I'll still need to carve out the butt shape
BTW the rods in the kit aren't much cop for cutting but they are good to resurface the foam that's torn up through rough cutting. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
 Posted: 04:22 - 28 Mar 2024 Post subject: |
Totally misjudged the kick-up at the back so glued on some offcuts to build up the back. Just using the hot-wire I've got this far:
https://i.imgur.com/OKq3zgg.jpeg
Just throwing the cover over it the front actually looks a lot better than the photo. The centre's a bit too thick so I think the next step is to try the electric sander method. Hot wire's not much use for carving things out.
If (and bearing in mind it's the Easter weekend) the rain ever stops I should really throw it on the bike to try out. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
 Posted: 21:47 - 30 Mar 2024 Post subject: |
Finally! The sun is out so a good excuse to be out working
I glued the base layer onto the foam. Laminating helps the foam hold the curve I've been encouraging with the elastic bands. As it is all this foam comes on a roll anyway so it was half way there.
https://i.imgur.com/INgHKHz.jpeg
Went at the foam with a sanding disk, turned out well I think:
https://i.imgur.com/6qIYlKM.jpeg
A 40 or 60 disk is fine for this sort of foam and I found using a certain side of the disk and one direction of travel gave the best results in terms of reducing tearing and kicking. e.g. drill clockwise, right side of the disk, travelling leftwards. Practicing on offcuts of foam helps ofc.
The other tool I used was a Scotch-Brite mop wheel to do a bit of carving at the back end. Hard to see in the previous photo but I managed to reproduce the rear kickup. Easier to appreciate after gluing the thin layer of reflex foam:
https://i.imgur.com/GmSsNkY.jpeg
If I have time tomorrow it'll be firing up the air compressor and stapling on the cover. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| Easy-X |
 Posted: 15:15 - 01 Apr 2024 Post subject: |
Staple gun time. If you're in any way interested in upholstery buy a pneumatic staple gun, makes life so much easier! Obviously you need an air compressor but only 60~100psi (4~7bar.) End result...
https://i.imgur.com/t3mbkNd.jpeg
Not perfect but 90% there. Might settle down a bit after a few rides (as the actress said to the bishop!) TBH it doesn't feel that different - thanks to the layer of reflex foam - but I know the core is a brick compared to the old marshmallow. I think the transition to the pillion seat turned out well
A nice little adventure but what did it cost?
Foam
https://www.efoam.co.uk/
They'll cut any size and thickness you like. I bought 3 types of foam plus a can of glue £37 including postage. I reused the original cover but you might also factor in replacement vinyl.
Hot wire cutter
https://www.amazon.co.uk/dp/B09CH4D2DK
Amazon £35, but you could substitute an old electric carving knife, maybe a really, really sharp knife at a pinch.
Air stapler
https://www.powertoolsdirect.com/clarke-csg1c-22-gauge-air-stapler
£33 + postage. IMO an essential item, a hand stapler wouldn't work on this seat base at all. (Plus a box of staples, £8)
I also used a drill + sanding disks but I'll not count those as "extra tools." Might want one of these to carve into things:
https://www.amazon.co.uk/dp/B002QRWHT2
All together probably a comparable price to sending it away for a basic rebuild (but not cost effective if you count the time.) ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| WD Forte |
 WD Forte World Chat Champion
| Back to top |
| A100man |
 A100man World Chat Champion
 Posted: 12:44 - 09 Apr 2024 Post subject: |
| Easy-X wrote: | TBH it doesn't feel that different - thanks to the layer of reflex foam - |
that would tie in with my observation that 'before' and 'after' don't look that different.. Hey ho. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Back to top |
| Easy-X |
 Posted: 13:55 - 09 Apr 2024 Post subject: |
I wasn't after a "diamond stitched look at me" seat. Bone stock aesthetic with proper support, thank you very much I think the thin layer of reflex foam I used goes some way to prove you only need a little for initial comfort not the entire seat made of marshmallow. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Back to top |
| WD Forte |
| Back to top |
| Easy-X |
| Back to top |
The last post was made 2 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
