| Author |
| Alexomidov |
 Alexomidov L Plate Warrior
 Posted: 17:32 - 13 May 2024 Post subject: 1996 YZF600 RPM Error Code and Revving Problem |
Hi everyone,
I'm located in the US and own a 96 Yamaha YZF600, this is not a Thundercat but the generation before that (I believe it was only produced in 1995 and 96. (will attach a photo if I can)
This bike has a different fuel pump assembly than both the FZR and the Thundercat, pump and sensor are both inside the tank with no mechanical petcock, there's only an electric button on the left side fairing that you can switch between on and reserve.
I recently went through the carbs and tank and rebuilt the fuel system, the bike runs good with 2 issues that might be related or not.
1- not at the start but after a couple minutes the tachometer starts cycling between the current RPM, 0 and 8000 RPM. My research says it's a fuel light issue but the light bulb works, the fuel reserve button works and the fuel pump/sensor connector is good (Checked it). The only thing haven't checked is the fuel level sensor, could that be the issue?
2- The bike doesn't like to rev over 7-8k. In 1st and 2nd gear it struggles at around 6k but if I push it it goes over and at around 9k it feels like a totally different animal, so much power! In the higher gears though, it won't go over 7-8k at all, in fact if I push it bugs down and goes even slower!
Does anyone know what the issue is here? I'm so confused!
Could it be all related to the RPM error code? Or I have 2 separate issues?
Appreciate any tips. ____________________ Weekends are for riding not watching TV!
| Back to top |
| A100man |
 A100man World Chat Champion
 Posted: 18:20 - 13 May 2024 Post subject: |
My guess
Two separate issues. I'd be stripping the carbs and looking for anomalies, or damage to diaphragms etc.. ____________________ Now: A100, GT250A, XJ598, FZ750
| Back to top |
| to v or not to v |
| Back to top |
| Alexomidov |
| Back to top |
| Alexomidov |
| Back to top |
| P. |
 P. Red Rocket
| Back to top |
| Alexomidov |
| Back to top |
| Alexomidov |
| Back to top |
| Kawasaki Jimbo |
 Posted: 21:52 - 15 May 2024 Post subject: |
On point 2, my ‘99 ZX6R had similar issues at 55k miles. The Dynojet needles had corrosion or wear on them. I replaced those needles and jets and haven’t had a problem since.
https://i.postimg.cc/T1Y2JV3d/IMG_0185.jpg
There were marks on the diaphragm slides too (as shown) but I reused them without issue. |
| Back to top |
| P. |
 P. Red Rocket
| Back to top |
| Alexomidov |
| Back to top |
| Alexomidov |
| Back to top |
| P. |
 P. Red Rocket
| Back to top |
| Alexomidov |
| Back to top |
| A100man |
 Posted: 22:01 - 20 May 2024 Post subject: |
| Alexomidov wrote: | | P. wrote: | Did you strip and clean them? Photos etc |
Yes, I cleaned everything, replaced all jets, screws and filters with new parts. everything was like brand new when I put them back together. |
Yes but what about the enrichment/choke fuel circuit and pilot circuit? these usually terminate at some tiny holes by the butterfly valve ____________________ Now: A100, GT250A, XJ598, FZ750
| Back to top |
The last post was made 1 year, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
