Fork oil is for cowards.
lingeringstin...
PostPosted: 13:03 - 22 May 2024    Post subject: Fork oil is for cowards. Reply with quote
So in lieu of ever finding a suitably priced springer/girder front end for my bike I went with some old Suzuki GS750 forks with BMW springs, mainly to give my bike an extra inch in length due to where the axle went in front of the stanchions as opposed to at the bottom like on most forks. My bike had always been twitchy because I used the shortest MZ TS250 frame (it's all I had) so the extra length did wonders for the handling.
However, in the beginning I stupidly used fork oil and it was almost as bad as the time I was running water in my bog standard MZ forks and it froze one winter's day so I had stiff forks. With no rear suspension either that was a pretty hairy ride into London that day on snow encrusted roads I can tell you. Sorted that out by putting antifreeze in with my fork water, but I digress.
These days I just use diesel. MUCH better handling and feedback than when they have fork oil or ATF in them. I can't remember if I've drilled the holes out bigger in the fork damping rod things (I usually do to increase the response time) but the diesel works brilliantly..
PostPosted: 14:23 - 22 May 2024    Post subject: Reply with quote
I'd imagine the risk of some of it aerosolising in the air gap then being compressed enough to detonate is a very small but non-zero number.
PostPosted: 15:50 - 22 May 2024    Post subject: Reply with quote
>200psi and hot? That's some hard ridin' Wink
PostPosted: 16:47 - 22 May 2024    Post subject: Reply with quote
I would imagine that once it was at 200 psi it'll be quite toasty already.
Triumph Sprint ST 1050
PostPosted: 16:55 - 22 May 2024    Post subject: Reply with quote
An air rifle can "diesel" oil vapour. And forks can get pretty damned hot. I've had the ones on my VFR too hot to touch before today (which explained where all the damping went).
lingeringstin...
PostPosted: 01:11 - 24 May 2024    Post subject: Reply with quote
[quote="stinkwheel"]An air rifle can "diesel" oil vapour. And forks can get pretty damned hot. I've had the ones on my VFR too hot to touch before today (which explained where all the damping went).[/quote]
I used to worry about the potential for detonation but after researching it I figured the pressures in my forks were probably too low to make diesel volatile (under normal riding circumstances).
However, I suppose if I was trying to do an Evel Knievel and leap the bike off of high places or if I was to hit one of the UK's finest potholes at high speed then maybe there could be some detonation, which would probably result in blowing the bottoms of the forks off with the wheel and the next step would be an almighty ass-over-tit down the road.
Ducked
PostPosted: 03:34 - 08 Jun 2024    Post subject: Reply with quote
I've wondered about brake fluid or antifreeze in my fairly deplorable forks if I ever get around to putting anything in them.
Antifreeze would be rubber compatible, which would be nice, especially if I back up my dodgy seals with condom segments, and a leak should be less hassle than with oil.
Brake fluid ditto. Contraindicated if I had paint that I cared about, but I don't carry that burden
PostPosted: 12:50 - 08 Jun 2024    Post subject: Re: Fork oil is for cowards. Reply with quote
I wonder if you ever reached a sweet spot when the ice turned to slush puppy..
The last post was made 1 year, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 57.19 Kb
